well now.... - TCCoA Forums
post #1 of 8 (permalink) Old 11-09-2006, 03:36 PM Thread Starter
I Break Stuff
94V8Thunderbird's Avatar
Send a message via AIM to 94V8Thunderbird Send a message via Yahoo to 94V8Thunderbird
well now....
so my headgaskets are toast on my 135K NPI 4.6 and the time has come to make the decision....Fix the NPI? or replace it with an 02 explorer motor....either way tear down has begun.
1988 Mustang GT 306, 4 bbl holley, edlebrock intake, nitrous cam, 4 inch cowl hood.
94 LX PI swapped Bird (sold) missing that car so bad
TCCoABAMF
94V8Thunderbird is offline
post #2 of 8 (permalink) Old 11-09-2006, 03:39 PM
Nativedetroiter's Avatar
rebuild? The thing is, what do you want, what do you want your numbers to be in the long run?
Nativedetroiter is offline
post #3 of 8 (permalink) Old 11-09-2006, 03:44 PM
justin case's Avatar
well since your tearing it apart anyhow just go pi, im collecting parts for it now and my car has 145xxx im just crossing my fingers that everything inside is in decent enough condition.
-Doug
95 T-bird, purple python,i'll drive it again.........someday.
http://www.facebook.com/home.php#/pr...73&ref=profile
justin case is offline
post #4 of 8 (permalink) Old 11-09-2006, 04:12 PM Thread Starter
I Break Stuff
i dont know, im thinking in the neiborhood of 425-450 RWHP. but i do agree about the going PI, i definately want to go PI.
TCCoABAMF
post #5 of 8 (permalink) Old 11-09-2006, 04:43 PM
Maxion$Mulla$'s Avatar
Yea man go PI. I you have around $6000 you can get the bigbore motor from modularperformace.com and some livernnoise stage 2 ported pi heads with bullit cams for about 300-350. You may get 400hp with some extra bolt-ons. Thats what im doing
Kevin
94 t-bird parting out in the classifieds
Selling a Panasonic cd player 40x4 with 1 set of preouts
and a Yamaha warrior front fender- yellow Classified as SPEED DEMON! Mutha
Maxion$Mulla$ is offline
post #6 of 8 (permalink) Old 11-09-2006, 05:55 PM
PI all the way.....
I would reccomend getting an entire PI engine instead of just heads/cams/intake, preferably an 02-04 aluminum explorer block, youll save around 86 lbs off the front end and boy does it make a difference. Get a jspec trans and your slug of a bird will soon be chirping the 2-3 shift HARD at around 50-55 mph and 5500 rpms
But I warn you now, upgrade the power of your engine and your old stock trans/converter will soon be TOAST. My trans lasted about 5 months behind the PI engine.....not fun, might as well do it all at once.
All Glory to God!
RIP JOHNNY LANGTON
96 LX PI/Jspec Pearl White. She enjoys eating ricers for breakfast
-MODS-
2002 PI 4.6L - Jspec Trans built by Darrin - 04 Marauder converter - Hayden 679 Trans cooler - Engine cooling modification - SCT Xcal2, tuned by Lonnie - 02 GT MAF and 99 GT Intake tube - removed silencer - 255 lph HP fuel pump - Aluminum Driveshaft - 3.73 TL - 245/60/15 BFGoodrich Radial T/A's - PBR front brakes - SCP Rear torsional load brace - SCP Solid rubber motor, transmission mounts - Rear Strut Tower brace and Diff cover brace by Rod
96_LX is offline
post #7 of 8 (permalink) Old 11-09-2006, 06:14 PM
95xbird's Avatar
Ya PI is a great way to go.But i heard that if you just do the PI cams and ports the hell out of the NPI heads you can out flow ported PI heads.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #8 of 8 (permalink) Old 11-10-2006, 02:15 PM Thread Starter
I Break Stuff
i have a 2000 Stang GT trans and stall, just needs to be j-modded.
TCCoABAMF
