where is the camshaft position sensor?? - TCCoA Forums
post #1 of 12 (permalink) Old 11-11-2006, 06:27 PM Thread Starter
bigbirddrifter's Avatar
well i threw the code po340, CAMSHAFT POSITION SENSOR malfunction,, so i bought the sensor, i got home opened my hood and have no clue where the h*** the sensor is.. i think i found the cranshaft position sensor right next to the a/c compressor, it resembles the camshaft sensor but its not the same,,, autozone told me the sensor is located in the center, upper part of the engine below the ignition coil??? i looked and there is nothing to be found.if anyone knows the real location of the sensor please help , i would really appreciate it. thanks
bigbirddrifter is offline
post #2 of 12 (permalink) Old 11-11-2006, 07:16 PM
its under the drivers side coil bracket.
as of 12-29-06 4.6 DOHC powered
fubar107 is offline
post #3 of 12 (permalink) Old 11-11-2006, 07:17 PM
Driver side under/behind power steering reservoir on timing cover.
post #4 of 12 (permalink) Old 06-19-2007, 04:38 PM
where is it located on a v6 3.8L engine for a 97 tbird
alanis is offline
post #5 of 12 (permalink) Old 06-19-2007, 04:58 PM
Where the distributor would be on a non dis equipped car.
post #6 of 12 (permalink) Old 06-19-2007, 05:00 PM
under the coil? where the spark plug wires connect to?
alanis is offline
post #7 of 12 (permalink) Old 06-19-2007, 05:03 PM
No on the engine near the intake manifold.
post #8 of 12 (permalink) Old 06-19-2007, 05:11 PM
dirtydog,
I've never seen one of these. Can you be a little more descriptive? this will be the first time I replace one if I find it.
alanis
alanis is offline
post #9 of 12 (permalink) Old 06-19-2007, 05:12 PM
Find the waterpump, look up above it on the engine. Between the intake and the waterpump ...basically. If I was standing in front of the car I'd reach my arm out and point.
post #10 of 12 (permalink) Old 06-19-2007, 05:19 PM
alanis, you should keep your questions to one section. It's not necessary to go to every section where a cam sensor was every talked about and ask around. Your question will get answered and posting everywhere won't make it happen any faster. And it doesn't look good.
post #11 of 12 (permalink) Old 06-19-2007, 06:00 PM
I saw the other thread that might be right the last one I did was a 96.
I don't own a 3.8 car anymore and the last one I did had a distributor.
post #12 of 12 (permalink) Old 06-27-2007, 12:56 AM
PHP Code:
alanisyou should keep your questions to one sectionIt's not necessary to go to every section where a cam sensor was every talked about and ask around. Your question will get answered and posting everywhere won't make it happen any faster. And it doesn't look good.
__________________
Chris my apologies for posting my question on multiple sections. To make a long story short I was getting impatient as I really wanted to get this done as my state inspection sticker has been expired for a while now. Thought the more I put it out there the better my chances that somebody that knew where it is would see it.
Once again thanks for your help. I did everything you instructed me to do and the codes are gone. A new one just popped out which I'm about to post for help. Please help if you can.
alanis is offline
