fuel pump not turning on. - TCCoA Forums
post #1 of 14 (permalink) Old 11-12-2006, 08:29 PM Thread Starter
TwoHaggard's Avatar
if i test the inertia switch n its gettin power. dose that mean the fuel pump relay is fine. bc i have this Schematic n thats the way it looks?...
thx.
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #2 of 14 (permalink) Old 11-27-2006, 03:17 PM Thread Starter
TwoHaggard's Avatar
any1 know? and when im testing at the constant control relay module the power to fuel pump, its pink n black wire lights up when i turn the key over. and same with the fuel pump control wire that is lite blue and orange. can any1 help.
dank
post #3 of 14 (permalink) Old 11-27-2006, 03:23 PM
PostSkank
StupidFly's Avatar
Its been a long time since the time I had to diagnose mine, so I cant remember too much about the layout (my manuals are thousands of miles away), but I do remember that my problem was a wire short somewhere between the under the dash, before the self-test connector. I lost track of the wire and had to bypass it.
I got so fed up when all the components and connections tested ok, that I removed almost all of my interior following the wire, testing every 3 feet or so. When I got to the dash, I lost track of the wire. But it tested ok at the self-test port, so I just tapped it and re-routed it.
I doubt this will actually help you out, hopefully someone can chime in.
math > pasta
StupidFly is offline
post #4 of 14 (permalink) Old 11-27-2006, 07:53 PM
svtbird88's Avatar
Yes if you have pwr at the PK/BK wire going into the inertia switch then the relay is on. The LB/O wire is grounded from the pcm to energize the coil in the fuel pump relay. It sounds like your on the right track good luck.
svtbird88 is offline
post #5 of 14 (permalink) Old 11-27-2006, 08:20 PM Thread Starter
TwoHaggard's Avatar
so..u think the fuel pump is bad.. it doesnt turn on. but sometimes it sputters like its going to start. and doesnt the relay click when u turn the key over?
hey thx alot guys.
dank
post #6 of 14 (permalink) Old 11-28-2006, 12:54 AM
CCRM is behind the passenger side headlight. If you put power to the pump and it works,but doesn't get power from the vehicle like it should change the module. That was one of fords better ideas.. Lets put several $5 relays inside a box, seal it up and charge $100 for it.
post #7 of 14 (permalink) Old 11-28-2006, 06:47 AM Thread Starter
TwoHaggard's Avatar
o ya i know. i had to change it like 5 months ago..
post #8 of 14 (permalink) Old 11-28-2006, 10:34 AM
svtbird88's Avatar
TwoHaggard I would ck for voltage at the front of the fuel tank DG/Y wire before you drop it. Also make sure you have a good ground, less than 5ohm of resistance. If those things ck out alright then I would say you need a new pump.
post #9 of 14 (permalink) Old 11-28-2006, 08:13 PM Thread Starter
TwoHaggard's Avatar
kk thx for the help ill look into that for 2marro.
post #10 of 14 (permalink) Old 12-24-2006, 01:34 PM Thread Starter
TwoHaggard's Avatar
wheres the DG/Y wire? bc its on the constant control relay module.......
post #11 of 14 (permalink) Old 12-25-2006, 07:52 PM
svtbird88's Avatar
There is a connecter on the pass side just in front of the tank all the wiring going to the pump runs through it. I would ck there before you drop the tank. That will eliminate all the wiring up to that point.
post #12 of 14 (permalink) Old 02-25-2007, 11:12 AM
jtsmith's Avatar
Good info right here--ours turned out to be the pump though--
Thanks for the great troubleshooting tips!!
jtsmith is offline
post #13 of 14 (permalink) Old 03-11-2007, 08:55 PM Thread Starter
TwoHaggard's Avatar
ok finally the weather became nice out. got to the tank. and it was wires came undone on the aftermarket pump. ha. wow. i am so happy thats all it was.
post #14 of 14 (permalink) Old 03-11-2007, 10:12 PM
svtbird88's Avatar
good job Glad it ended up to be a easy/cheap fix for you.
