injector swap question... - TCCoA Forums
post #1 of 5 (permalink) Old 11-12-2006, 08:55 PM Thread Starter
trying to finish up a 97 CV to 96 t-bird swap.was changing the fuel rails out when i noticed the injectors were different.i used the CV injectors because they were cleaner and the bird injectors came out of the intake without the "covers"?.the part #'s are different,anyone know if the car will run right?
shelbyseven is offline
post #2 of 5 (permalink) Old 11-12-2006, 09:33 PM
twin turbo 281's Avatar
if they came from a 97 crown vic they are most likely still 19#ers and as long as they plug in then they should be fine. Are they skinny injectors??
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #3 of 5 (permalink) Old 11-13-2006, 06:06 AM Thread Starter
the injectors are fatter than the ones that came out of the bird...
post #4 of 5 (permalink) Old 11-13-2006, 05:22 PM
girdnerg's Avatar
They should be just OK. My Brother's 97 Cougar must have had that same swap because his are the fat type and work fine.
Rob
girdnerg is offline
post #5 of 5 (permalink) Old 11-13-2006, 07:24 PM
The fater ones are gen 1 and the skinnier ones are gen 2. The skinnier ones actually flow more fuel at higher pressure and they provide better fuel atomization. Then gen 3 are also the improved design but have the newer oval connectors and wouln't plug into an older harness without a plug adapters.
