4.6 electric water bump - TCCoA Forums
post #1 of 24 (permalink) Old 11-13-2006, 10:10 AM Thread Starter
coggonobrien's Avatar
just wondering if anybody has used one and if they recommend any brands. this will be for a dohc.
coggonobrien is offline
post #2 of 24 (permalink) Old 11-13-2006, 10:19 AM
Adam B.'s Avatar
Send a message via AIM to Adam B.
I believe racecougar has one. From what I've read, everyone seems to be quite impressed with them. I don't have any specifications on it though.
Stuff goes here.
Adam B. is offline
post #3 of 24 (permalink) Old 11-13-2006, 10:29 AM
I run a Moroso pump on my 5.8l.
I know this doesn't help you much, but I'm glad I have my pump....you can cool the car in the staging lanes.
post #4 of 24 (permalink) Old 11-13-2006, 07:20 PM
Yep, I'm running the Meziere pump on my XR7. As far as I know, that is the only one available for a 4.6L DOHC. I'm completely happy with mine.
-Rod
post #5 of 24 (permalink) Old 11-13-2006, 07:35 PM Thread Starter
this is prolly a stupid question but is that just a dumby pullie on urs rod? just to allow the use of the orignal belt?
post #6 of 24 (permalink) Old 11-13-2006, 07:53 PM
Yep, it's just an idler pulley.
-Rod
post #7 of 24 (permalink) Old 11-13-2006, 08:11 PM Thread Starter
where did you find it at? i check Meziere' website and they didn't have it listed in their catalogue. but it was an 2005 catalogue
post #8 of 24 (permalink) Old 11-13-2006, 08:13 PM
Summit, ebay, any of the modular forums, etc.
-Rod
post #9 of 24 (permalink) Old 11-15-2006, 08:07 PM
Maxion$Mulla$'s Avatar
any clue on the power gains?
Kevin
94 t-bird parting out in the classifieds
Selling a Panasonic cd player 40x4 with 1 set of preouts
and a Yamaha warrior front fender- yellow Classified as SPEED DEMON! Mutha
Maxion$Mulla$ is offline
post #10 of 24 (permalink) Old 11-15-2006, 08:27 PM
I haven't had a good dyno pull with the car since I installed it, but the Meziere pump alone has dropped my E.T.'s by a SAE corrected average of two tenths. That would equate to 15-20 rwhp, though it is only advertised to produce a 11 rwhp gain.
-Rod
post #11 of 24 (permalink) Old 11-15-2006, 09:02 PM
driller's Avatar
I have the same on my Mark VIII.
I don't think I gained 2 tenths but there was a gain in the butt dyno. By the time I got to the track with it I had a converter too, so the actual gains due to the pump itself were unknown.
driller is offline
post #12 of 24 (permalink) Old 11-15-2006, 10:54 PM
Battery's Avatar
Send a message via AIM to Battery
I noticed they also advertise one without a pulley. Would that work on a DOHC as well with a smaller belt, or is the idler needed?
"It's all in the reflexes"
LE RIP
Now 96 Mark VIII
Battery is offline
post #13 of 24 (permalink) Old 11-16-2006, 09:19 AM
driller's Avatar
The idler is required to do the proper belt wrap in the crank, which is what turns the belt driven accessories like power steering, AC and alternator.
driller is offline
post #14 of 24 (permalink) Old 11-16-2006, 09:35 AM
Silenced's Avatar
Is the electric pump something that I could install with the engine in the car? I will probably get one, but I don't want to kill myself intalling it
Silenced is offline
post #15 of 24 (permalink) Old 11-16-2006, 09:40 AM Thread Starter
looking at mine (its on an engine stand) i can't see any reason why not but somebody correct me if i'm wrong. while we're on the subject of pulleys and belts, has anybody done an a/c delete on their car? if you were gonna do this you would need a differant belt anyone so you ought to be able to run a water pump that does not have the idler. thinking about it you could do a simple set up with the crank pulley, alternator, power steering pump and then a single custom idler, just a thought. a buddy of mine did that with a 3.8 he built. even went so far as to relocate the alternator.
post #16 of 24 (permalink) Old 11-16-2006, 11:14 AM
driller's Avatar
The 4.6L modular water pump has got to be one of the easiest ever to change - in or out of the car.
Look at the belt wrap on the DOHC 4.6L and you will see what I mean as far as crank pulley contact. Without the water pump or dummy pulley on the electric pump, you will not be turning any belt driven accessory. Deleting the AC will not help. Most AC delete kits have a bracket and idler pulley in place of the AC.
driller is offline
post #17 of 24 (permalink) Old 11-16-2006, 12:12 PM
BIG PETE's Avatar
The shrouded Cobra pump is a gain of about 5 RWHP over a stocker, so how much a gain you see with the electric one is really up in the air. After switching to the Cobra pump, I'm a little worried that next summer's temps may cause some cooling issues for me. For that reason, I would like more info on the electric pumps, but I can't find anybody who has had problems with them. I think they are good, but I need something rock solid since the Cougar is my only car.
Anybody have any issues with reliability on these?
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #18 of 24 (permalink) Old 11-16-2006, 04:07 PM
Thread Killer
midwestbird's Avatar
How do you wire it up? Was it hard to do?
As of 10-20-06 DOHC POWERED
Painted Vista blue as of 08
242hp/251tq
[email protected] [email protected] Byron Il
RobertP plate modded: 5-23-08
midwestbird is offline
post #19 of 24 (permalink) Old 11-16-2006, 04:28 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
Pete
Pete,
I have the Cobra pump from the get-go on the 5.0L. I think you will be ok with the Cobra pump. My car actually ran cooler home, than it did on the way down to Texas. I am considering the Electric pump down the road but right now I don't really see the need for it.
TGJ is offline
post #20 of 24 (permalink) Old 11-16-2006, 05:05 PM
sweet thats nice ecspeacaily if you have a/c eleminator too. Nice
Kevin
post #21 of 24 (permalink) Old 11-16-2006, 08:13 PM
BIG PETE's Avatar
Originally Posted by TGJ
Pete,
Usually, the big bore does run cooler than the old engine did, but I think that's common of the aluminum block. I'm not so sure though, since I haven't talked to others about it, but it makes sense. The aluminum will move more heat faster than the iron block will.
Pete
-97 XR-7
-5.0 Big Bore ...
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #22 of 24 (permalink) Old 11-18-2006, 01:08 AM
Peter M's Avatar
Here's another $.02...
The link on the Meziere site is here.
The install was VERY easy, as was the wiring. Just have everything you need BEFORE you start.
I've found my temps to be lower, and more consistant now, too. On little note, if you have underdrive pullies, you WILL need a shorter belt than stock, but this is mentioned in the Meziere instructions.
Peter M
SOLD 1996 4.6l Thunderbird-(fast) PI intake, custom exhaust, Bullet-Resistant Tranny™, blah, blah, blah
2007 VW GTI-(faster) United Grey, 18" wheels, APR stage 1 chip, and... uh... that's it for now.
________________________
..this space for rent..
Peter M is offline
post #23 of 24 (permalink) Old 11-18-2006, 08:29 AM
sc0tty8's Avatar
Send a message via AIM to sc0tty8 Send a message via MSN to sc0tty8
I have been eyeing up one of those and udp's to free up some parasitic HP.
1994 Merc Cougar 4.6L-Bone Stock
2002 Nissan Maxima SE 6MT-Bone Stock
sc0tty8 is offline
post #24 of 24 (permalink) Old 11-18-2006, 05:09 PM
Send a message via AIM to Slowpoke
I got one on my 4.6...I noticed a definite change in the way the car revved..I;m supercharged as well....COnsider it free HP..and cooling yoru car inbetween rounds at the track is priceless
Going for broke!!!!
Slowpoke is offline
