Crown Vic Police - TCCoA Forums
post #1 of 10 (permalink) Old 11-13-2006, 12:57 PM Thread Starter
Crown Vic Police
What is there on a 4.6 Police Interceptor (P71) motor that is desirable for the 94 4.6 in the way of upgrades?
http://images19.fotki.com/v358/photo...Tbird01-vi.jpg
1994 White (WT) TBird - 4.6 L SOHC with 4R70W
"Sir, if you were my husband, I would poison your drink."
-Lady Astor to Winston Churchill
"Madam, if you were my wife, I would drink it."
-His reply
Rehab progress link
Today's Progress
DScruggs is offline
post #2 of 10 (permalink) Old 11-13-2006, 01:16 PM
Lonnie's Avatar
What year? The engine is the same as a Tbird for the same year model. The upper intake is swapped around though.
www.blueovalchips.com
1992 5.0 Thunderbird Sport, 328 rwhp 347 rwtq
1995 Mark VIII, 287 rwhp 305 rwtq
I have seen the truth and it makes no sense
Lonnie is offline
post #3 of 10 (permalink) Old 11-13-2006, 01:55 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
From what I recall, all police cars had the same motor as the production vehicles of the same year. The difference was in the suspension, gears, etc.
tinman_72 is offline
post #4 of 10 (permalink) Old 11-13-2006, 01:56 PM
95xbird's Avatar
Didnt they also have a reprogramed ECU as well?
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #5 of 10 (permalink) Old 11-13-2006, 02:03 PM
Darrin's Avatar
Yeah but unless you have a CV or GM you can't use it.
The transmissions are different. They have a long output shaft and tailshaft housing. Won't work on our cars either. Other than that they are internally the same. There is no difference in the engines at all from a civilian CV or from the same year (insert car here) with a 4.6
Unless you have a 99-00 Mustang GT that is. Those are better.
Darrin
Darrin is offline
post #6 of 10 (permalink) Old 11-13-2006, 05:19 PM Thread Starter
OK
But would a 2002-2003 Police CV be a donor of any value to upgrade a 1994 T Bird in any way?
-His reply
Rehab progress link
Today's Progress
DScruggs is offline
post #7 of 10 (permalink) Old 11-13-2006, 05:27 PM
mercutio's Avatar
Yes--better cams, better heads and a better intake. It should add 40-50 hp or so once you get it tuned. But you'll need to make a few other changes too, like swapping over to the 96-97 Thunderbird fuel line from the filter forward.
Executive Editor, Ford Builder Magazine--hit me up if your ride is worthy!
mercutio is offline
post #8 of 10 (permalink) Old 11-13-2006, 06:31 PM
Lonnie's Avatar
The CV PI's EEC only increases shift pressures and slightly raises the shift points and speed limiter. When reprogrammed this doesn't matter since these will be changed making it just like any other CV performance program.
Lonnie is offline
post #9 of 10 (permalink) Old 11-14-2006, 02:51 PM
Chapter Director Coordinator
jamesD's Avatar
you forgot the all important fact that doesn't matter
the newer po-po packages had reinforced bracing around the fuel tank so it wouldn't explode like a pinto when hit from the rear
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #10 of 10 (permalink) Old 11-14-2006, 05:42 PM
3rd Gear Chirper
hotbird's Avatar
They have silicone coolant hoses, and an engine oil cooler also.
hotbird is offline
