which series flows - TCCoA Forums
post #1 of 8 (permalink) Old 07-28-2002, 02:01 PM Thread Starter
Send a message via AIM to blackbird96
which series flows
i have a 96 4.6lx, n i was looking into what series flows sound the best, thanks for the help
blackbird96 is offline
post #2 of 8 (permalink) Old 07-28-2002, 05:25 PM
NickFL's Avatar
Send a message via AIM to NickFL Send a message via Yahoo to NickFL
I have the 40's on my '95
I like the sound of the 40's. They are much louder than the Dynomax mufflers I had before.
Later, NickFL
2004 COBRA COUPE #3036 of 3768 OXFORD WHITE; 601.5 RWHP @ 6450 RPM; 595.2 lb/ft Torque @ 3750 RPM; 18* Timing | 18.5 PSI Boost | 11.94 AF
Whipple 2.3L | Steeda idler | Reichard idler pulleys | Metco 2# Lower | Reichard 3.0 Upper | Magnaflow Catted X-pipe | Magnaflow Catback | Focus Pumps | 8AN lines | CPR rails | SD 60lb injectors | TR6 Plugs | Revolution chip | MAFiA | BBK T-body | Steeda CAI | Custom heat exchanger | Royal Purple coolant additive | Kenny Brown super subs | Steeda lowering springs | IRS bushings | IRS weld in braces | FPDM rewire | MT ET Street Radials | Centerforce clutch | Steeda billet quad and cable | Lunar boost and fuel gauges | Autometer gauge panel
NickFL is offline
post #3 of 8 (permalink) Old 07-28-2002, 05:58 PM
94birdnj's Avatar
still got those dynomax's?.......i'm looking for something a little louder than stock w/ a nice growl but not something annoying,........hell i like listening to jazz every once in a while. heheheh. i like to maintain the luxury feel of the car but w/ the power too.
94birdnj is offline
post #4 of 8 (permalink) Old 07-28-2002, 06:03 PM
NickFL's Avatar
Nope...Sorry...
I got rid of them pretty quickly. I dont remember who bought them, but they were bought by someone from the club. I hope they are going to good use.
Later, NickFL
NickFL is offline
post #5 of 8 (permalink) Old 07-28-2002, 07:07 PM
Refrigerator Raider Hater
GreenBird's Avatar
Matt R has a vid clip of his 70 series. if he doesn't post it, I can e-mail it to you.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #6 of 8 (permalink) Old 07-28-2002, 10:00 PM
Red Thunder's Avatar
If you want loud and don't mind drone get the 40 series. I was going to get the "Delta Flow" 40 series because they have less drone but still have an aggressive throaty tone. I settled for Ravins because of the higher flow and they are getting deeper and throatier every day.
96 Tbird LX
Red Thunder is offline
post #7 of 8 (permalink) Old 07-30-2002, 12:05 AM
The Hitman's Avatar
I've got a set of 10 series single chamber race mufflers sitting here if you want them.. Ok. So maybe that's a little loud and with the 3 inch inlet and outlet.. probably wouldn't work.
1995 Mustang GT
Bolt ons. Stock H/C/I for now.
13.2
2001 Sentra SE
Short Ram Intake only.
15.3
Kerry/Edwards '04
The Hitman is offline
post #8 of 8 (permalink) Old 07-30-2002, 07:50 AM
WaLieN's Avatar
Send a message via AIM to WaLieN
96 Tbird LX
Do the Ravins have any 'freeway drone?'
As for getting a muffler, the classic sound of a Flowmaster 40 series sounds good, but your car will sound like the rest of em.
☼1997 Ford Thunderbird LX - 4.6L -K&N Panel Filter-Steeda U|D Pulleys-Steeda 180* Thermostat-Removed Intake Silencer-Polyurethane IRS Bushings-Tranny Cooler-Urethane Tranny Mount
☼1993 Mazda RX-7 Touring [VR] - Rotary Power rebuilt turbos & motor w/ 3mm Apex Seals - PWR Radiator - PFS Cat-Back - RB Intake Duct w/ K&N Panel - Manual Boost Controller - KG Differential Brace - Gotham Engine Torque Brace - Aluminum 45mm Front STB - B&M Short Throw Shifter - PFS Column Mounted Boost Gauge - Falken Azenis ST115s [235/40ZR17] on Speedy Mashie Silvers
WaLieN is offline
