94 Cougars - TCCoA Forums
post #1 of 3 (permalink) Old 01-07-2006, 01:40 AM Thread Starter
Question 94 Cougars
I have two 94 Cougars. One is wrecked and it has a 4.6L I think. The good one has a 3.8L V6 which I just did a headgasket on and now have water leaking from behind the timing cover and also into the oil. Can anyone tell me if I can put the V8 into the V6 car without having to use the Transmission from the V8 car. Both cars are automatics and have multi port injection. Also, will I need to use the flywheel and torque converter from the V8 car, or the one from the V6 car. Thanks in advance for any help.
iammikeri is offline
post #2 of 3 (permalink) Old 03-18-2006, 10:12 AM
iammikeri, Sorry I can't help with your question, but any chance your selling parts off the 94?
cul8er is offline
post #3 of 3 (permalink) Old 03-18-2006, 10:17 AM
jk69cat's Avatar
use the v6 car to fix the body on the v8 car, less work, you would have to change out wiring, engine, trans rear end , fuel pump exhaust , etc
mn12 less!
jk69cat is offline
