sc repair - TCCoA Forums
post #1 of 8 (permalink) Old 06-06-2009, 09:51 PM Thread Starter
Banned
Send a message via AIM to 1989superchicken Send a message via MSN to 1989superchicken
sc repair
all idiot's need not respond
Well i got the tensioner's pulled and sent off to have the mp sping's installed.
I got the new plenum installed,egr is fixed,supercharger bypass is fixed.
I am still wating on tb to show up. Next weekend it's geting allignment and front wheel bearings packed. Then i can start testing at the track even though it's hot.
I still won't see my best's run's until fall.
so far this summer i intalled maff/tb/blowertop/dalke tune with more timing/
new shocks and complete front end.
future build within the next year
60 pound injectors
255 fuel pump
5% jack shaft
retune
copyed build on head's= cam like mark's setup
[email protected] holeshot convertor with anit balloning plate
75 to 100 shot of nos______one or both the blower and nos or jut the blower
95 s-port with mp plenum
3:73 gears
true front mount ic
1989superchicken is offline
post #2 of 8 (permalink) Old 06-10-2009, 12:02 AM Thread Starter
Banned
well i still need to put on cowl panels's and hood.
I need bearings and font end greased and a alignment
but she's running very nice.
post #3 of 8 (permalink) Old 06-10-2009, 11:40 AM
13's or Mildly Broken
This may be a complete shot in the dark.. but have you looked into the specs that are in Mike's SC (yes, Marc's old one) I remember it being a high lift and not sure if you'll want that with having an auto? Shoot Dave an e-mail to see what he recommends for head/cam combo - but first, determine what your final goal is so you won't have to purchase parts more than once. One thing I didn't see was a shift kit. A Lentech Valvebody won't be cheap, but it's a GREAT upgrade.
Otherwise, sounds good. Hope it works out for ya.
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #4 of 8 (permalink) Old 06-10-2009, 12:21 PM Thread Starter
Banned
well i was told the tranny has a stage 1 [email protected] shift kit in it .It shift's pretty hard.
This is the tranny we put in from ben ,then had rebuilt.
yea i need to dig up my saved info on marc's heads and look at the cam
post #5 of 8 (permalink) Old 06-10-2009, 04:42 PM
Ah, ok - didn't know you had something in the trans already. I'd still seriously consider a Lentech VB though. The manual control is great. Do you still have to do the 1-D-1 shuffle to get 2nd gear?
-Melon
2000 Explorer 5.0
Melon is offline
post #6 of 8 (permalink) Old 06-10-2009, 11:22 PM Thread Starter
Banned
i have never even done that before
post #7 of 8 (permalink) Old 06-11-2009, 01:21 AM
Silenced's Avatar
Marc's setup was high lift.
Having an auto would be better since Jason has stall to assist with the lower "low end" torque.
You will have to use a wet shot.
I'm not sure the 255lph pump will be enough.
Needs MPX case.
Powered by:
Megasquirt EMS, Vortech Superchargers, Renegade Racing, Gator1980Transmission, Innovative Motorsports, Devil's Own, Magnaflow, Eibach, KYB, Kooks
Silenced is offline
post #8 of 8 (permalink) Old 06-11-2009, 03:57 PM
You don't want to - it's a PITA. To get the AOD into 2nd gear and hold it, you shift from 1st to drive, and back to 1st. It's not the easiest thing on the trans.
Another reason why I really like Lentech - it allows you manually shift between the gears and lock out OD at the track. Yes, you can shift your AOD into Drive, but I've seen AOD's shift into overdrive when the shifter is in drive.
-Melon
2000 Explorer 5.0
Melon is offline
