Looking for Ideas - Detonation in Exhaust - Page 2 - TCCoA Forums
 12Likes
post #31 of 35 (permalink) Old 06-15-2019, 07:14 PM Thread Starter
MaddMartigan's Avatar
Good news. I pulled the transmission and the problem was the bolts that I used. The shoulder on the bolt was too long which didn't allow the pressure plate to evenly seat. I put on thick washers and the problem is solved. The car is back together and I've verified that everything is working as it should.
Rodeo Joe and Grog6 like this.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #32 of 35 (permalink) Old 06-15-2019, 07:23 PM
Great! sucks you had to go through all that trouble for something so simple, but it’s also good it was just that simple
MaddMartigan likes this.
post #33 of 35 (permalink) Old 06-20-2019, 06:38 PM
gordonm1's Avatar
Let's see that fire eating dragon make some smoke.
gordonm1 is offline
post #34 of 35 (permalink) Old 06-20-2019, 06:51 PM
S4gunn's Avatar
Nothing sucks more than to have everything together and you have to pull the trans or lift the engine out just to fix some issue like dropping something or the oil shaft into the oil pan. I've had to do that... twice.
http://goo.gl/csaet4
S4gunn is offline
post #35 of 35 (permalink) Old 06-20-2019, 09:29 PM Thread Starter
Yeah, you know the struggle is real for sure. Considering the amount of real world experience I have with all of this, I'm actually surprised I've gotten this far without significant problems.
Grog6 and CDsDontBurn like this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
Similar Threads
Detonation=power loss? Rob Engine - 4.6L & 5.4L 11 09-26-2003 12:04 PM
Post headswap detonation gone! Embalmer Engine - 4.6L & 5.4L 3 06-24-2003 09:05 AM
Detonation ? scott Engine - 4.6L & 5.4L 23 05-11-2003 10:56 PM
Detonation after chip install trakslacker General Tech 6 05-02-2003 05:07 PM
Detonation won't stop mercoug302 Engine - 4.6L & 5.4L 5 03-25-2003 12:08 PM
