Car Radio Help - TCCoA Forums
post #1 of 8 (permalink) Old 05-07-2008, 05:01 PM Thread Starter
CometGSR's Avatar
Car Radio Help
Guys,
Is there anyone here that can help me wire up a CD Player for my bird? I am getting a wire adapter, so it should be pretty easy for whoever can give me a hand with it. Its just a CD payer, nothing too fancy.
Thanks!
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #2 of 8 (permalink) Old 05-07-2008, 10:13 PM
rtalber1's Avatar
Originally Posted by CometGSR View Post
Guys,
Thanks!
I could help, as long as you have wire drawings to fall back on. I put mine in 7 years ago, but I could still handle it. Let me know when you need the help.
Big Rob's Car---1998 Lincoln Mark VIII LSC Collector's Edition #314 in Cordovan Red. 89,xxx miles----
1997 T-BIRD LX 116,xxx miles--- Lost Due to a Divorce!!!
rtalber1 is offline
post #3 of 8 (permalink) Old 05-08-2008, 07:24 AM Thread Starter
CometGSR's Avatar
When I get the radio and pieces, I will let you know.
-=James
CometGSR is offline
post #4 of 8 (permalink) Old 05-08-2008, 08:27 AM
jco1385's Avatar
hey man, i'm not local....i just saw the title.
if you get the aftermarket harness, the wires are labeled as to what they are. match those to the corresponding wires on the radio (also labeled in a drawing im sure) and you should be all set.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #5 of 8 (permalink) Old 05-09-2008, 07:51 AM
shaggy433's Avatar
Send a message via AIM to shaggy433 Send a message via MSN to shaggy433 Send a message via Yahoo to shaggy433
they should be color coded if you buy a wire harness..Then all you have to do is match green solid to green solid, green/black to green/back ect ect...
94 XR7 One of 71,026
Magnaflow Cats, Magnaflow DI/DO 2 1/4"true duals with 3 1/2" stainless tips...reverse glow gauges, 7 color a-pillar gauges, 20% tint, JVC HD deck, 10" Kicker square, 400rms mono Kicker amp.
And it can be seen here
shaggy433 is offline
post #6 of 8 (permalink) Old 05-10-2008, 10:03 PM
Listening on 141.850 mHz!
Gonzalo Duque's Avatar
I'm not bad either when it comes to wiring up car stereos, are you getting new speakers too? The factory speakers are good to show to the garbage man.
Gonzalo Duque "Gonzo"
1997 Lincoln Mark VIII LSC 4.6L Cobra V8
1997 Thunderbird Limited Edition 4.6L V8 - gone.
Might be a 2005-2007 Jaguar XJ-8 L in my future.
Westland, Michigan - but I'm from central New Jersey!
http://www.hoodliners.net - My hoodliners I make!
Gonzalo Duque is offline
post #7 of 8 (permalink) Old 05-11-2008, 01:34 PM
rtalber1's Avatar
Actually, stock premium speakers are not half bad, when I worked for FORD, they tweaked the stock ones to sound just as good as aftermarket. I have mine on a high pass filter, so I do not get any bass from them.
rtalber1 is offline
post #8 of 8 (permalink) Old 05-11-2008, 02:23 PM
Then they must have changed up a bit since I last pulled the 2 pairs out of my ride! All 4 of them had brittle paper cones, and every car before then had them too.
I've got Infinity Kappa 682.7cf 2-way 6x8s with the adjustable tweeters at all 4 spots and they sound great!
Glad to hear that Ford is making strides in audio and telematics as well.
