how to go about installing pi cams.. - TCCoA Forums
post #1 of 24 (permalink) Old 10-26-2006, 04:00 PM Thread Starter
motor city poster
Red96Bird's Avatar
first of all im doing this in ohio since its where i go to school.... so if any of you wanted to help its kinda out of the question..
i purchased a set of pi cams with bolt on sprockets from quick cat, all i want to know is how about to go installing these cams, is it as simple as..
remove valve covers..
unbolt sprockets from cam..
remove bearing caps from cams-head..
then re assemble in reverse order??
as i said, bolt on sprockets, 96 4.6.
thanks,!
Patrick
Red96Bird is offline
post #2 of 24 (permalink) Old 10-26-2006, 04:15 PM
FordFanatic's Avatar
should be as long as you have the tool to do it that way.
http://forums.tccoa.com/showthread.p...ain+wedge+tool
FordFanatic is offline
post #3 of 24 (permalink) Old 10-27-2006, 07:20 AM
Cough cough I'm pretty sure you have to take the front cover off in order to get the timing chain off and to set the timing after the new cams are installed! Im almost positive you have too but not 100%.
97qwikcat is offline
post #4 of 24 (permalink) Old 10-27-2006, 07:40 AM
cough cough, did you check out the link i gave him?
post #5 of 24 (permalink) Old 10-27-2006, 08:13 AM
cough cough no sorry!
post #6 of 24 (permalink) Old 10-27-2006, 12:03 PM Thread Starter
motor city poster
Red96Bird's Avatar
so it looks like im gonna add another 30 bucks to my cam install budget..no problem..
thanks!
post #7 of 24 (permalink) Old 10-27-2006, 03:02 PM
T-bird_fan's Avatar
Send a message via Yahoo to T-bird_fan
Ya but think of all the time you will save not having to remove the front cover and all the crap that goes along with that.
J-Mod, MMC D/S, 24k gvw Tranny Cooler, Mark VIII TC,13” KVR Frt brakes, FRPP 3.73 rear, PI cams & Intake plus P&P NPI heads with the cooling mod, 1 3/8" Rr swaybar.
T-bird_fan is offline
post #8 of 24 (permalink) Old 12-12-2006, 11:14 AM
thanks!
Hey did you end up buying that tool?
post #9 of 24 (permalink) Old 12-12-2006, 11:59 AM Thread Starter
motor city poster
Red96Bird's Avatar
waiting for christmas money!..then the cams will go in.. im a broke college student on a budget
why do you think i waited so long to get the cams cheap from you...hahaha
just playin around
post #10 of 24 (permalink) Old 12-13-2006, 10:30 AM
LOL that's cool with me I needed to get rid of them. If you bought that tool I was gonna ask to borrow it a day but I took my valva covers off last night and found out it aint a lifter or rocker it's inside the front cover so I won't even need the tool.
post #11 of 24 (permalink) Old 12-13-2006, 11:41 AM
The Great Obucina's Avatar
cough cough, take off the front cover and do it right or run the risk on PTV.
"Booyah". Stu Scott.
The Great Obucina is offline
post #12 of 24 (permalink) Old 12-13-2006, 01:59 PM
cough, cough
Any of you guys have a hernia???
Grasshopper is offline
post #13 of 24 (permalink) Old 12-13-2006, 02:06 PM
LOL
Yeah in my case the front cover is coming off!
post #14 of 24 (permalink) Old 12-13-2006, 02:21 PM Thread Starter
motor city poster
Red96Bird's Avatar
alright....
lets say for sake i dont buy this tool...what all is needed when taking off the front cover..
obviously just by pulling the valve covers i need new gaskets, or at least i know i do...
so i pull the timing cover off, what else would i need? im talking anything, tools, gaskets, rtv, whatever?
post #15 of 24 (permalink) Old 12-13-2006, 02:54 PM
Traveler's Avatar
Just a simple question. If the tool does its job, and the chain doesn't come off of any of the timing gears, how would the timing have changed from when it was set at the factory? Of course if the tool does slip and the chain comes loose, then you'd just have to do it the long way anyway, so you're still ok right?
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #16 of 24 (permalink) Old 12-13-2006, 03:17 PM Thread Starter
motor city poster
Red96Bird's Avatar
thats what i figured^
post #17 of 24 (permalink) Old 12-13-2006, 04:06 PM
im sure the tool would work just fine. mechanics on flat rate have to make their money somehow right.
post #18 of 24 (permalink) Old 12-14-2006, 07:10 AM
alright....
you shouldn't need any gaskets or RTV. The thing about that way is you gotta take more stuff off.
post #19 of 24 (permalink) Old 12-14-2006, 09:29 AM
girdnerg's Avatar
I'm trying to learn too, so I have a question also.
If you take the cover off, don't you have to have yet another tool (or a pair of them) to keep the cams from rotating when you take the chains off? That's what I've read, so now I'm really confused (what's new about that, lol).
Rob
girdnerg is offline
post #20 of 24 (permalink) Old 12-14-2006, 09:46 AM
Traveler's Avatar
I was reading the instructions on the AndersonFordMotorsports tool. It looks like it'd be a very good idea to have a second set of hands helping out with the swap. One to install the cam and one to hold the tool safe and steady.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #21 of 24 (permalink) Old 01-03-2007, 10:25 AM Thread Starter
motor city poster
Red96Bird's Avatar
well i purchased that tool, i should have it by Friday, if i get a chance ill take a pic of it and post it online, then next weekend i should be installing the cams.. so ill let you guys know how it turns out.
oh yea, then if it works well, if anyone wants to use it you can buy it from me or just borrow it...
post #22 of 24 (permalink) Old 01-03-2007, 10:34 AM
Traveler's Avatar
Sounds great. Let me know how it works out, and I'd be happy to pay shipping on it both ways to borrow it when I put my cams in (Unless of course it'd be cheaper to just buy it!). And if you'd like to just bring the tool to Southeast KS in person to show me how to use it, that'd be cool to. Planning on spending a weekend in May working on the car with a bunch of KS, MO, IA members. (OK to, but haven't heard from any yet)
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #23 of 24 (permalink) Old 01-03-2007, 11:03 AM
Rob
Pending on the cam I used a adjustable wrench to hold the cam.
post #24 of 24 (permalink) Old 01-03-2007, 02:57 PM Thread Starter
motor city poster
Red96Bird's Avatar
in the instructions, it says to compress the followers in a vise to bleed them down, is this necessary, or if so could this be done with a c-clamp?
