"The voltage at terminals A and B with engine on should be 10.5V
The voltage between C and D should be .34 - 1.96 V at idle.
If not you may have an electrical prob in the sensor head. "
I'm getting 14.0 between A and B and .90 between C and D...
Hooked up an OB2II scanner and got the following:
p0102 mod$10
MAF or VAF
A
Circuit Low Input
p0141
02 Sensor Heater
Circuit Malfunction
Bank 1 Sensor 2
then same, Bank 2 Sensor 2
Then it repeated the codes again for a total of 6.
Dan
Related Threads
TCCoA Forums
1.5M posts
26.9K members
Since 2002
