89 sc engine - TCCoA Forums
post #1 of 5 (permalink) Old 05-29-2007, 09:47 PM Thread Starter
89 sc engine
Will a 89 SC 5 speed engine swap into a 96 tbird? Is it basically a direct swap, or is there any modificatons that need to be made?
FastThunder is offline
post #2 of 5 (permalink) Old 05-29-2007, 10:32 PM
rbrown's Avatar
No blower?
rbrown is offline
post #3 of 5 (permalink) Old 05-29-2007, 10:49 PM
twin turbo 281's Avatar
why ditch a good modular motor for a headgasket puking, snout ripping problem. Thats like taking a step back unless your talking about a 96 that has a 3.8 in it?
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #4 of 5 (permalink) Old 05-30-2007, 02:13 PM Thread Starter
my car is the v6 3.8, the sc egine has the blower and everything elce
post #5 of 5 (permalink) Old 05-30-2007, 10:46 PM
13's or Mildly Broken
Long story made short - yes it will work. But there's some wiring changes that need to be done. Get a good schematic of the 96 and one from the 89. Do you have any of the harnesses from the 89 to go with the engine? Do you have good access to the car that the motor came out of?
And after the motor is in, you haveta think about what to do for a transmission if you haven't beefed it up yet. And then the rear end if you don't have an 8.8. And if the SC axles are heavier/beefier/stronger than the LX ones, you'll probably want those too just to be on the safe side. And don't forget the fuel pump. I know the LX and SC don't have the same pump.. and while your at it, might as well upgrade the pump to a good 255 unit.
Yes - there will be some mods to be done - mostly wiring though (atleast off the top of my head)
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
