popopop......(fouled plug(s) i hope) - TCCoA Forums
post #1 of 4 (permalink) Old 06-03-2007, 01:21 AM Thread Starter
mybird_91's Avatar
Send a message via Yahoo to mybird_91
ok so i got my exhaust leak fixed today......well.....yesterday now......anyway......so it drives fine to work and sounds way better than before..... then i go to leave and pop pop popopop........... so i check to make sure all wires are on nice and snug cause i had that problem once before. all fine, adjusted the tune to see if that would help......no timing light don't help, but it seemed fine when i test drove it around the parking lot. drove home and it was missing around 2000 rpm.........also little bit of a lifter rattle at 3/4 throttle only for a second. right now i'm running autolite plat. plugs factory specs. should i go w/ motorcraft copper plugs or stay w/ the autolite plats? and could the exaust leak i had have caused the plug(s) to foul out?
1994 Chevrolet Camaro Z28
LT1 350
K&N Intake and Flowmaster Exhaust
1995 Lincoln Mark VIII
hollow front cats, 3rd cat still there, no resonator, replaced by a single 40 series flowmaster, 2 3"x18" tips out back. screamin demon coil packs, mallory pro wires, motorcraft platinum plugs. intake resonator delete.
mybird_91 is offline
post #2 of 4 (permalink) Old 06-03-2007, 08:24 AM
thunderbirdlver's Avatar
Send a message via AIM to thunderbirdlver Send a message via Yahoo to thunderbirdlver
that kind of reminds me of when my distributor went on my 5.0 birdy.
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
thunderbirdlver is offline
post #3 of 4 (permalink) Old 06-03-2007, 11:37 AM Thread Starter
mybird_91's Avatar
ohh crap.......don't say that.......not in my budget right now.
LT1 350
post #4 of 4 (permalink) Old 06-03-2007, 01:44 PM Thread Starter
mybird_91's Avatar
the culprit is dr. side rear plug wire touching the manifold. cracked the wire and was grounding out.
LT1 350
