Engine Shaking - TCCoA Forums
post #1 of 11 (permalink) Old 06-04-2007, 09:41 AM Thread Starter
Question Engine Shaking
Hi everyone, I have a small problem with my cat. When i start it up the engine shakes even after it has warmed up, i have checked the plugs and they all are in good shape no fouling or anything else, gap is good on them. Also when driving down the road you can feel what i call a miss every so often, plug wires seem to be in good shape although i haven't changed them in about two years now. Any ideas what might be causing my shake and miss?
Dartanion is offline
post #2 of 11 (permalink) Old 06-04-2007, 09:49 AM
jco1385's Avatar
vacuum or mount? maybe?
jco1385 is offline
post #3 of 11 (permalink) Old 06-04-2007, 09:54 AM Thread Starter
Engine Shaking
Mounts are good. As far as a vac's maybe, I don't hear anything like it would be sucking air. But will check vac's again.
post #4 of 11 (permalink) Old 06-04-2007, 10:27 AM
jco1385's Avatar
i have to change my motor mount and trans mount, but it doesn't "shake" at idle. it does at speed when i let off. i think you have a vac leak somewhere. clean the maf (or unplug it) and see what that does.
jco1385 is offline
post #5 of 11 (permalink) Old 06-04-2007, 01:19 PM
white lincoln's Avatar
How do you know they are good? I thought mine where good until I replaced them and one fell apart in my hand as I was pulling it out from under the car....
Might shook at idle too.
white lincoln is offline
post #6 of 11 (permalink) Old 06-04-2007, 01:45 PM
jco1385's Avatar
hey, white lincoln, how hard were they to change with engine in the car? specifically the pass. side. thanks
jco1385 is offline
post #7 of 11 (permalink) Old 06-04-2007, 07:03 PM
Kelsey Smith's Avatar
Send a message via MSN to Kelsey Smith
Might verify that the harnesses going to the injectors is firmly connected.
"WHAT CONE?!?!
1997 T-Bird Sport, 'Interceptor' (12 ESP 2008-2012)- CAI, 2.25 duals, Flowmaster 40 series, Clear corners, BBK 70mm Throttle Body, TrickFlow upper intake, PI Intake, BBK adjustable fuel pressure regulator, LE stripes, Bullitt-style gauge faces. 18x9 wheels, Sniper tuned, 3,620 pounds
1991 Ford F250 - Air restrictor delete. Cat delete.
1991 T-Bird 'Interceptor II' (12 CP 2013-) - Race-prep, Full custom "interior", Carb'd 302, Trick Flow twisted wedge heads, stage 1 cam, Custom Koni coil-overs front, Koni yellows rear, Cobra front brakes, fuel cell, 18X9 wheels, 275/30 Hoosier A6, 4.11 T-Lok. 3000 pounds
2004 Toyota Solara SE - V6, Sport package, Muffler delete, 17X7 wheels, 235/50 Conti ExtremeContact DWS
Kelsey Smith is offline
post #8 of 11 (permalink) Old 06-04-2007, 09:49 PM
mine shakes a little bit off & on at idle or startup, most everything is new i wouldnt worry too much about it as long as its not excessively bouncing around. just think of it as a massage chair the warm startup & bad idle, it must be a ford thing have a friend with a 92 f250 with a 351 and it will do a little shimmy randomly too
"it WANTS to be fast, and that is all that matters"....
mike884_2 is offline
post #9 of 11 (permalink) Old 06-04-2007, 10:07 PM Thread Starter
Smile Engine Shaking
Ok well i have checked every thing I know on this kitty, so i wont worry to much about the little shake at start up, what does concern me is the miss feel i get going down the highway, any suggestion's on that? And thanks everyone for the input.
post #10 of 11 (permalink) Old 06-11-2007, 01:11 AM
Dartanion, I think our Cougars are related. Mine has a shakey idle and when at hwy speeds it feels like the power comes and goes. Only 46,000 miles.
V10man is offline
post #11 of 11 (permalink) Old 06-11-2007, 05:41 AM Thread Starter
Well we could be kin, Since i posted that. I have done a few few things to the little kitty, the ignition coil was replaced and i replaced the plugs and wires yesterday so far the shake and the power that came and went at highway speeds seems to be gone now,she is purring like she is suppose to. Maybe try these things and see if it helps.
