MAF voltage - TCCoA Forums
post #1 of 3 (permalink) Old 06-06-2007, 12:23 PM Thread Starter
MN1293-232's Avatar
Question MAF voltage
Does a MAF voltage of 0.85DCV at 195 degress coolant temp at idle seem a little high on a 93 3.8L? I thought the reading was supposed to be around 0.5 to 0.6DCV if I wasnt mistaken.
MN1293-232 is offline
post #2 of 3 (permalink) Old 06-06-2007, 05:39 PM
That's too technical. Spray the sensors and the connections down with electrical contact cleaner. Replace the filter too.
Hollywood Ed is offline
post #3 of 3 (permalink) Old 06-07-2007, 08:18 AM
"The voltage at terminals A and B with engine on should be 10.5V
The voltage between C and D should be .34 - 1.96 V at idle.
If not you may have an electrical prob in the sensor head. "
This is what I found out and had posted in another thread.
Dan
gs69350 is offline
