96 3.8 Thunderbird Runs rough. - TCCoA Forums
post #1 of 6 (permalink) Old 06-11-2007, 11:47 AM Thread Starter
OK here it goes. I have been trying to get this car running right for over a year now. When I start it, it runs rough and hesitates when I hit the gas. For a while it hardly ran at all but a friend of mine changed the fuel pump and that helped alot. Now it runs but I am left with this rough idle and hesitation when I step on the gas. I brought it to my mechanic and he changed the head gaskets. $1,000 later and the car did not run any better. I checked the plugs yesterday and they are black and smell like fuel. I am hopping someone here can help me because I'm stuck. Thanks for your time.
dan1973ct is offline
post #2 of 6 (permalink) Old 06-11-2007, 11:50 AM
Clean/replace MAF sensor, check all vacuum lines, check fuel pressure, change plugs & plug wires, change coil.
post #3 of 6 (permalink) Old 06-11-2007, 06:07 PM
MN1293-232's Avatar
Did you check the fuel injectors? You could have one that is constantly open thus your fuel smell and black plugs.
MN1293-232 is offline
post #4 of 6 (permalink) Old 06-11-2007, 07:48 PM
It sounds like you may possibly have a problem with an O2 (oxygen) sensor.
freeloader is offline
post #5 of 6 (permalink) Old 06-11-2007, 07:56 PM
Who is John Galt?
I'd add the IAC to that list as well.
"Won't work, can't be done"
cougar_guy04 is offline
post #6 of 6 (permalink) Old 06-11-2007, 08:37 PM
I agree. Good point.
