Where does this wire go? - TCCoA Forums
post #1 of 14 (permalink) Old 06-11-2007, 07:45 PM Thread Starter
Can anyone help me out with this wire?
The colour didn't quite come out properly in the picture; it's a yellow wire with a white stripe. The car is a 94 Thunderbird LX with a 3.8L.
It doesn't seem to effect the running of the car, but it's driving me nuts to see the wire there and not connected to anything.
freeloader is offline
post #2 of 14 (permalink) Old 06-11-2007, 08:07 PM
95xbird's Avatar
Sending unit in the back of the motor on the water pipe.It's right below your hand
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #3 of 14 (permalink) Old 06-11-2007, 08:11 PM
Agreed, though I doubt that he has that sensor on his '90, in which case it gets left disconnected.
-Rod
post #4 of 14 (permalink) Old 06-11-2007, 08:12 PM
95xbird's Avatar
-Rod
94 3.8
Its slow, Really.
LS1 KILLER
95xbird is offline
post #5 of 14 (permalink) Old 06-11-2007, 08:36 PM Thread Starter
I actually swapped the engine from my 90 Cougar into the 94. I picked up the 94 for $200 as it had a dead engine (spun bearings). I'm assuming that this wire was for running the electric fan. I don't like electric fans, so I used my old clutch fan setup from the 90!
Thanks for the replies.
post #6 of 14 (permalink) Old 06-11-2007, 08:40 PM
Oops, I thought I saw a "90" on his profile.
That wire has nothing at all to do with running the electric cooling fan. It's used for the auto climate system.
-Rod
post #7 of 14 (permalink) Old 06-11-2007, 08:43 PM Thread Starter
Cool. It's good to know these things. The engine swap was a pain in the butt, just because of the crappy 3.8L engine mounts. I'd like to string up the engineer who designed them.
post #8 of 14 (permalink) Old 07-19-2007, 04:40 PM
basskid's Avatar
Send a message via AIM to basskid
So if I do not have auto climate control, this wire does not get hooked up? I just did some fiddling at the back of my motor, and this wire showed up. I have a 96 4.6 without auto climate. This wire is driving me crazy...
Stock 96 block with 04 gt heads & intake, 03 gt intake tube and MAF, along with a 180 deg stat and mild j mod...
Mandrel bent catless 2.25" true duals with dynomax super turbos
Vogtland .75" drop springs with sport / cobra shocks
XCAL2 with custom dyno tune
231hp, 280ftlb
Car is officially for sale... call me...
basskid is offline
post #9 of 14 (permalink) Old 07-19-2007, 05:19 PM
Yes, it goes to nothing.
post #10 of 14 (permalink) Old 07-22-2007, 09:15 PM
Mine also goes to nothing. I'm so glad to have seen this. Thanks so much all!
houtex727 is offline
post #11 of 14 (permalink) Old 07-22-2007, 09:18 PM
what exactly does it do for the auto climate control?
i just converted to satc and thats the only sensor i dont have, and everything seems to work
post #12 of 14 (permalink) Old 07-23-2007, 11:31 AM
It senses the temperature of the coolant and prevents the blower motor from operating when the coolant isn't hot enough and you want the heater to work. This stops it from blowing cold air when you want hot. If you don't have it plugged in or don't have the sensor, the blower motor will run no matter what. No big deal.
post #13 of 14 (permalink) Old 07-23-2007, 02:46 PM
mybird_91's Avatar
Send a message via Yahoo to mybird_91
i'm glad i found a 93 cougar donor for my 93 t-bird!
so many people said its gonna take weeks to get it swapped......took a day and a half 1st day set the motor in and hooked up the trans and motor mounts, 2nd day all the wires found their home.
1994 Chevrolet Camaro Z28
LT1 350
K&N Intake and Flowmaster Exhaust
1995 Lincoln Mark VIII
hollow front cats, 3rd cat still there, no resonator, replaced by a single 40 series flowmaster, 2 3"x18" tips out back. screamin demon coil packs, mallory pro wires, motorcraft platinum plugs. intake resonator delete.
mybird_91 is offline
post #14 of 14 (permalink) Old 08-02-2007, 11:55 PM
Wow, I have wondered for months what that was there for. I swapped a 2004 3.9L out of a mustang into my 96 and could not for the life of me remember where the hell that wire was attached before I pulled the motor. My wife was laughing at me telling me I shouldn't have been drinking. Well HAH, who's laughing now? Cool I can cut it out now. Thanks guys!
mn12v6x2 is offline
