My stuff is finally here, I have questions - TCCoA Forums
post #1 of 11 (permalink) Old 06-13-2007, 09:38 PM Thread Starter
Stroked and Blown
BlakTbird96's Avatar
Today, I recieved my 3.8 single-ported heads from a '98 Mustang in the mail. I also have the upper and lower intakes off of the junked '96 Tbird 3.8. So, I will be taking them over to the machine shop soon.
How much should I get these ported over? Are there any certain specifications I need to tell the dude? Basically, I want my car to have alot more power...but I don't want it to be strictly a drag car. I want it to stay street legal and reliable but have alot more power.
How far should I get these ported?
Also, when I go to buy the gasket set, are the head gaskets for the 96 Tbirds/98 Mustangs the same? I know the heads are pretty much the same.
Also, I need the ARP Studs for a 96 Tbird 3.8 block, correct?, regardless if the heads are 98 Mustang.
I'm not going to get the torque to yield head bolts.
My other home:
Mid-AtlanticMN12's
'96 Ford Tbird 3.8 SC
BlakTbird96 is offline
post #2 of 11 (permalink) Old 06-13-2007, 10:30 PM
As far as the porting goes I can't really help you there as I have no experience in that area. However I can tell you that the headgaskets and ARP studs are the same for 96/98.
post #3 of 11 (permalink) Old 06-14-2007, 08:56 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
i thought i told you to get the chevy 2.8 v6 studs?
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 11 (permalink) Old 06-14-2007, 02:31 PM Thread Starter
Stroked and Blown
I was worried that the 2.8 Chevy studs may be too small or too big, thats why I was going to get the studs for a Ford 3.8, unless you're 100% sure they will work.
My other home:
Mid-AtlanticMN12's
post #5 of 11 (permalink) Old 06-14-2007, 02:33 PM
Motorboatin' SOB
big mike's Avatar
i had the 2.8s on my 3.8. they work, ok? the tbird studs are too long and need to be clearanced cuz they interfere with the exhaust manifold studs, or so i read. plus, the 2.8 studs are about $40 cheaper than the tbird ones.
your call, man.
2014 GT
1990 300ZX TT
big mike is offline
post #6 of 11 (permalink) Old 06-14-2007, 03:09 PM Thread Starter
Stroked and Blown
Yeah, sure, thats it? Anyways, I may change the cam too and throttle body but I'm not sure yet. Anyways, do you know how much I should get them ported?
BTW-big mike, I noticed you have a 93 Tbird. Mine's a 96. I will ask summit if the 2.8 Chevy head studs will still work when I call them.
EDIT-I just called summit and ARP. Summit doesn't carry them supoposedly and ARP doesn't even have Ford 3.8 or Chevy 2.8 head studs listed in their system...
My other home:
Mid-AtlanticMN12's
post #7 of 11 (permalink) Old 06-14-2007, 04:25 PM
Motorboatin' SOB
big mike's Avatar
well, ill be damned. i dont see them on summit either.
google "arp head studs chevrolet 2.8", click the first link, and get the HEX head, $82 ones. better yet, i still have my arp studs for sale. less than 2k miles on them. shoot me $60 and they are yours. and YES, they are reusable.
what makes you think summit knows? i, and a couple other guys, have used these studs on our 3.8s with no problems. hell, even look on sccoa. the year doesnt matter, as long as it's for a ford 3.8.
2014 GT
1990 300ZX TT
big mike is offline
post #8 of 11 (permalink) Old 06-14-2007, 04:32 PM
Resident Line Creator
th3subtl3on3's Avatar
I'm excited as well. I just purchased my forged internals for the new engine I will be building. Got the pistons, rods, 4.2 crank, and bearings for about $1462 shipped.
-Brian
th3subtl3on3 is offline
post #9 of 11 (permalink) Old 06-14-2007, 09:14 PM
I'd just do a little smoothing in the bowls and gasket match the intake runners. DO NOT hog out the exhaust ports, just clean them up a little.
-Rod
post #10 of 11 (permalink) Old 06-15-2007, 12:36 AM
dDUBb's Avatar
The Chevy ARP Head studs for the 2.8 are part number 233-4003 .. not sure if thats 6 or 12 point, but one is cheaper than the other, it just depends which type of socket you want to use on it.
The Ford 3.8 SC ARP studs are 153-4001, and are a little taller, they will require you to grind the exhaust manifold for clearance - even though ARP was supposed to have taken care of this problem.
It would also be a good idea to chase your threads with a bottoming tap, so you can thread the studs all the way down without any interference.
- Dan
dDUBb is online now
post #11 of 11 (permalink) Old 06-15-2007, 01:46 AM
rbrown's Avatar
http://store.summitracing.com/partde...3&autoview=sku
What he said before me. The sheevy parts work well.
Mild port. Don't really touch the exhaust unless they really know what they are doing. Just a clean up. I had just a valve job done on mine with new seats and they run great.
rbrown is offline
