oil pressure problem - TCCoA Forums
post #1 of 7 (permalink) Old 06-19-2007, 09:04 PM Thread Starter
Maxion$Mulla$'s Avatar
Has anyone ever had there oil pressure drop all the way down when ever you are stopped at a traffic light or slowing down?
Kevin
94 t-bird parting out in the classifieds
Selling a Panasonic cd player 40x4 with 1 set of preouts
and a Yamaha warrior front fender- yellow Classified as SPEED DEMON! Mutha
Maxion$Mulla$ is offline
post #2 of 7 (permalink) Old 06-19-2007, 09:53 PM
If anyone has I'm sure they've also seized their motors shortly after. If your oil pressure gauge (read: idiot light) is going all the way down when you stop or slow down, you probably have a bad sending unit or the connection to the sending unit is loose/corroded/damaged. Check it out. It's by the oil filter and has 1 wire going to it.
post #3 of 7 (permalink) Old 06-21-2007, 03:31 PM Thread Starter
allright thx alot
Kevin
post #4 of 7 (permalink) Old 06-21-2007, 03:34 PM
jco1385's Avatar
mine dropped all the way down when it ran hot and blew th hg's. if you don't hear the "death rattle" you've probably got a bad sensor
jco1385 is offline
post #5 of 7 (permalink) Old 06-21-2007, 04:27 PM
Have you checked to be sure the oil is full?
Jay
FordMan77 is offline
post #6 of 7 (permalink) Old 06-21-2007, 07:46 PM
Bradone's Avatar
Jay
and Ding, ding, ding, you get KISS award!
Brad
[email protected] (engine/trans is stock)
Bradone is offline
post #7 of 7 (permalink) Old 08-03-2007, 12:14 AM
mine used to shudder when at idle at lights. It would drop real low and bounce really fast. Id give it a little gas and it would go back up and clear up. After I changed out motors (and along with that all sensors) it stopped. Maybe I got to it before it locked up. But it did it for many years with no other symptoms.
mn12v6x2 is offline
