Cooling system question - TCCoA Forums
post #1 of 5 (permalink) Old 06-25-2007, 06:43 PM Thread Starter
white lincoln's Avatar
Today my temp gauge hit an all time high of almost 3/4 on the needle. I had the AC on full blast as well. The temp stays at about 1/4 for the first 20 minutes of driving and will start going up as I put a heavy load on it or as above, it's hot out (alsmost 100) and the AC is cranking and putting the throttle down - alot (rush hour - everyones in MY way!)
I am not sure if it's the pump or the radiator.
New heads
Little loss of fluid
New hoses
New T-stat - 192
New belt
Fan comes on when the temp is at 1/2 - everytime and when the AC is on, the fan is on full time. So the fan is working, t-stat is good, correct mixture of fluid.
What else could it be? My bet is to replace the water pump @ $50 and then the rad at $$$ if it needs it. Rad is about 10 years old and the engine has 120k.
Thanks!
white lincoln is offline
post #2 of 5 (permalink) Old 06-25-2007, 09:16 PM
I suspect the radiator to be the problem. If the water pump isn't leaking or making noise and the shaft doesn't have any play, it should be good.
post #3 of 5 (permalink) Old 06-25-2007, 09:22 PM
95xbird's Avatar
Why don't you do a pressure check???I just recently found a very slow leak in my system that has been there since I did the PI swap.(2 years now).It only leaked when under pressure.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #4 of 5 (permalink) Old 06-26-2007, 03:12 AM
Blindloser1080's Avatar
Might look into what was happening with my car.
Mine was doing the same, the gauge was dancing and would climb whenever my subwoofer hit and would "overheat", and I replaced the brass sensor that actually goes to the gauge (it was like $5.00) and I havent had a problem since with it climbing ever since.
Blindloser1080 is offline
post #5 of 5 (permalink) Old 06-26-2007, 12:19 PM Thread Starter
Thanks guys. My neighbor has a pressure testing unit and I will do that first. After that, a better gauge!
