EGR tube fix? - TCCoA Forums
post #1 of 4 (permalink) Old 06-29-2007, 07:19 PM Thread Starter
EGR tube fix?
Borrowed the picture from another thread. Don't worry about the text in the picture.
Is it possible on a 3.8L engine to reroute this vacuum line to an intake manifold source?
My EGR tube developed a split and then broke in half. I've made a new one out of copper but don't want to solder up the little vacuum tee to the new tube as I'm afraid the exhaust heat will just melt the solder anyhow. Or does it need exhaust gas for a proper reading?
freeloader is offline
post #2 of 4 (permalink) Old 06-29-2007, 07:44 PM
If you hook it up to intake manifold vacuum you will have serious problems. It needs to be hooked up to that exhaust tune and receive positive pressure that changes based on EGR valve position, not negative pressure based on engine load.
post #3 of 4 (permalink) Old 06-30-2007, 03:49 AM Thread Starter
Thanks for the help! I'll have to solder in a small tube then
post #4 of 4 (permalink) Old 07-02-2007, 11:53 AM
The Stevinator's Avatar
i'd be surprised if the solder holds. good luck.
The Stevinator is offline
