93 3.8 Check Engine Light - TCCoA Forums
post #1 of 3 (permalink) Old 07-04-2007, 06:16 PM Thread Starter
MarknKellie's Avatar
Send a message via AIM to MarknKellie Send a message via MSN to MarknKellie
Question 93 3.8 Check Engine Light
The Check Engine (Or Idiot Light as my Wife calls is) is lit up in my dash, upoon checking the codes I find out that the Ait Intake Temp. Sensor is bad & so is my MAF sensor. Since I have to replace the MAF sensor as w ehole unit & not just the sensor. Would now be a good time to upgrade from the stock 50mm MAF to the 56mm I keep hearing about? I havent installed a CAI yet, but it is planned to happen within the next couple of weeks.
So, keep the stock 50mm with the stock air intake or go ahead & upgrade to a 56mm for future purposes?
The only this im wondering about is, If i do step up to the 56mm MAF & run teh car with the stock air intake system, will it make the car run funny or not hurt a thing?
::Edit::
Another thing, what about a new Thermostat... 180 or a 160? Comments, suggestions?
Last edited by MarknKellie; 07-04-2007 at 08:01 PM. Reason: I forgot something... LMAO, happens alot!
MarknKellie is offline
post #2 of 3 (permalink) Old 07-05-2007, 01:17 PM
Don't bother with an upgraded MAF. It won't do your engine any good, and you'll need a tune for the car to run correctly. With a tune, a colder thermostat, some premium fuel and altered timing you might be able to get a couple more ponies out of it but don't set the bar high. It's a highly anemic engine you are working with. Unless you plan on getting a tune, don't bother changing anything else.
post #3 of 3 (permalink) Old 07-05-2007, 03:00 PM
My daughter's 93 was upgraded to a 70mm MAF without any problems, runs pretty good too! (shameless plug Jon!) The 94 and up 3.8 cars came with a 70mm MAF anyway. Maybe you can find a used one. You might want to clean the MAF first and see what you get.
