splitport 3.8 performance - TCCoA Forums
post #1 of 16 (permalink) Old 08-03-2007, 10:28 PM Thread Starter
interested in swapping my stock, slow, crappy, knocking 3.8 for the splitport 3.8... what can i expect as far as performance gains? is it a worthwile swap? has anyone went to the track with this motor? what does car run?
oldfordisbetterfords is offline
post #2 of 16 (permalink) Old 08-04-2007, 12:16 PM
I've been running a 2000 Splitport 3.8L in my 94 LX daily driver since late '02. Completely stock with an UD crank pulley, dual exhaust and 93 octane, it made 165 rwhp/198 rwtq way back when we tuned it. On the 87 octane tune, it makes 8 rwhp/12 rwtq less.
A stock singleport 3.8L will lay down 120 rwhp on its best day, so it is a pretty decent gain.
-Rod
post #3 of 16 (permalink) Old 08-04-2007, 01:00 PM
Resident Line Creator
th3subtl3on3's Avatar
Or go with a 4.2 Single port.
-Brian
th3subtl3on3 is offline
post #4 of 16 (permalink) Old 08-04-2007, 06:19 PM Thread Starter
want to do easiest & cheapest
post #5 of 16 (permalink) Old 08-31-2007, 05:11 AM
dribrednuht is offline
post #6 of 16 (permalink) Old 08-31-2007, 06:07 AM
4.2L singleport = 4.2L shortblock with singleport heads/intake.
-Rod
post #7 of 16 (permalink) Old 09-01-2007, 02:15 AM
The_Ghost's Avatar
http://www.3.8mustang.com ; there is a LOT of info on there. (edit, remove the L)
A guy named Jerome is running twin turbos on his 3.8L and IIRC is putting down HP numbers in the high 300s, and he's not the only one. Turbocharging the 3.8 splitport is quite popular, and recently, I saw a post (I think on SCCOA) of an M112 on a 3.8L splitport.
The speedkills M90 kit has been under development for god knows how long, and who knows if it will ever be a real, purchasable kit.
Anyhow, yeah, there is a fair amount of stuff avail for the 3.8L.
-Ghost
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #8 of 16 (permalink) Old 09-01-2007, 10:52 AM
fl96thunderbird's Avatar
Send a message via Yahoo to fl96thunderbird
That link lead to paternity tests and such. lol
Try this one: http://www.3.8mustang.com/
SOLD the 96 in favor of a 97 ABS, TC, Sunroof
OEM E46 Bi-Xenon D3S
XBox 360 gamertag: POPIMP96
fl96thunderbird is offline
post #9 of 16 (permalink) Old 09-03-2007, 04:38 PM
Originally Posted by dribrednuht View Post
Like Rod said, it just has the single port heads and intakes. This is the build that I am currently doing as of right now. Granted, it won't have the air flow like the splitport does, but I am going for ease of install. With the upper and lower intakes ported and polished, and runners shortened, it will flow efficiently enough. I'm not taking to easy way out of the build either, later down the road a power adder will be added. It will take time, but it is worth it.
-Brian
post #10 of 16 (permalink) Old 09-03-2007, 06:28 PM Thread Starter
idk what to do with car as far as new motor now... ppl say splitport swap other say v8 swap others say sell car... car running more & more like crap so i need to figure something out soon.. it'll be my winter/spring project...
post #11 of 16 (permalink) Old 09-03-2007, 09:52 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
v6power.net also has a lot of good info (more than 3.8mustang IMO )
A split-port swap is fairly easy, but then, so is sticking a 4.2 shortblock under your exhisting stock heads/intakes, etc. A combination of the two would be very nice, you could see 180rwhp on stock heads/intakes with that combo. With ported heads/intakes and a moderate cam, you could see 250-300rwhp. Add some nitrous in to the mix and it would be a fun car.
The speedkillz kit will NEVER come in to production, I promise. He got so caught up in carbon fiber what nots that it became more of a form than function project and Im sure he's lost his motivation by now. supersixmotorsports.com made an M112 kit for the split-ports, but it has not yet become a production item. At least they have a running operating car with the prototype though. I see that coming out soon
-Thomas
Thomas is offline
post #12 of 16 (permalink) Old 09-04-2007, 01:26 PM
Now are you referring to the single port setup with the 250-300 range, or the split port? Matt told me that I should see roughly 220ish to the rear wheels with the setup that I am doing, NA that is. Honestly, I will be happy with anything above 200.
-Brian
post #13 of 16 (permalink) Old 09-04-2007, 05:26 PM
Uber Luber
Thomas's Avatar
split-port 4.2 is what i was referring to.
Thomas is offline
post #14 of 16 (permalink) Old 09-13-2007, 12:42 AM
4.2L shortblock + SSM 94-98 power pak stage 2+ = ???HP
post #15 of 16 (permalink) Old 09-13-2007, 02:24 PM
I think the easiest thing would be to swap in a complete 4.2 from an F-150. However, you will need to modify your hood or get a new one. If you want the stock hood, take that same 4.2 and swap on a set of single-port heads, then sell the split-port stuff and make a little money back.
Steve
S_Mazza is offline
post #16 of 16 (permalink) Old 09-13-2007, 05:21 PM
Uber Luber
Thomas's Avatar
if youre going for cheap power, 4.2 shortblock with 99+ mustang intakes is the way to go. Putting stock single-port heads and intakes would be pointless, they just dont flow enough.
as for a stock shortblock with SSM heads/intakes/cam...I would guess around 230rwhp. Seriously though, if you got the same package for the splitport you could see 260-280rwhp.
-Thomas
Thomas is offline
