headgasket cost... - TCCoA Forums
post #1 of 4 (permalink) Old 08-19-2007, 11:36 PM Thread Starter
headgasket cost...
how much does it usually run to get it done AT A SHOP. I cant do it myself.
I had a low coolent light this morning.. and this afternoon i was idling in the parking lot and my exhaust was smoking...
car hasnt overheated though
NiteFire is offline
post #2 of 4 (permalink) Old 08-20-2007, 02:36 AM
I believe a shop will be around $1,000 - $1,400. It's not all that hard to do it yourself but it's understandable if you simply do not have the means. The 96/97's aren't as notorious for blowing HG's as their 95-earlier counterparts. Are you sure it is not simply a heater hose or intake gasket that might be the problem? You should check the plugs and the oil to see their condition.
post #3 of 4 (permalink) Old 08-20-2007, 08:02 AM
jco1385's Avatar
+ 1. you could probably have an engine put in for about the same too.
jco1385 is offline
post #4 of 4 (permalink) Old 08-20-2007, 09:28 AM
I got quotes 7 years ago for 850 up to 1500 bucks!
For 200 bucks and 7 hours of my life I did it myself and have put another 80,000 miles on the car since then.
Bangster is offline
