I need some help here!! - TCCoA Forums
post #1 of 2 (permalink) Old 08-26-2007, 02:48 PM Thread Starter
chadder1313's Avatar
Send a message via AIM to chadder1313
Well i finally got my car all back together. I recently just put rods and mains in. So i got everything hooked up and all the fluids in and i go to start it and nothing. Just keeps cranking. So i chcked the fuel pressure: good. Checked for spark and its got spark. I even sprayed some starter fluid in just to see what it would do and it did fire. So im thinking the injectors are not injecting fuel. My question is what would cause this? I need some help!
Chad MA-DRT
1992 SC AOD
1990 SC M5R2 "Beater"
www.mamn12.com
chadder1313 is offline
post #2 of 2 (permalink) Old 08-26-2007, 06:48 PM
fl96thunderbird's Avatar
Send a message via Yahoo to fl96thunderbird
Are the injector wire hareness' actually pluged in? Its the little things that bite you in the butt. Or maybe the wrong harness plugged into the wrong injector, so fuel isn't sprayed at the right time?
SOLD the 96 in favor of a 97 ABS, TC, Sunroof
OEM E46 Bi-Xenon D3S
XBox 360 gamertag: POPIMP96
fl96thunderbird is offline
