Not the water pump Squeakin! - TCCoA Forums
post #1 of 7 (permalink) Old 08-29-2007, 07:19 PM Thread Starter
I feel great! Just spent nearly 8 hrs changing the stupid water pump b/c i thought it was producing its own orchestral symphony under my hood. Put everything back together in high hopes of hearing the serenity of absolute silence when i crank my bird. WRONG!!!!!!! Still have the same damn squealing. What the hell could it be? FYI Drivebelt is new.
crisqob is offline
post #2 of 7 (permalink) Old 08-29-2007, 09:12 PM
davis97xr7's Avatar
try spraying the pullies with wd40 or something and see if any of them are the problem
-Joe-
1994 Ford Thunderbird SC 5-Speed
1996 Ford Mustang SVT Cobra #1251
davis97xr7 is offline
post #3 of 7 (permalink) Old 08-30-2007, 08:31 AM
jco1385's Avatar
alternator or a/c clutch. can you tell where it's coming from?
jco1385 is offline
post #4 of 7 (permalink) Old 08-30-2007, 09:04 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
bad fan motor? does the squeaking continue after you kill the engine?
2014 GT
1990 300ZX TT
big mike is offline
post #5 of 7 (permalink) Old 08-30-2007, 12:54 PM Thread Starter
It's not the fan motor. I've WD'd all pulleys. After which the noise seemed to get worse. it's was localized around the water pump, which is why i changed that first. but now, i can;t really tell where the noise is comin from. An old man told me to take a length of pipe and use it as a stethoscope to try and pinpoint the squeal. I gonna feel real dumb if it's just a stupid idler pulley or something.
crisqob is offline
post #6 of 7 (permalink) Old 08-30-2007, 01:06 PM
jco1385's Avatar
is your tensioner spinning? could be stuck causing squeal.
jco1385 is offline
post #7 of 7 (permalink) Old 08-30-2007, 02:03 PM
It's probably the idler or tensioner pulley. Take the belt off and spin everything to see what squeaks.
