How to check if rad fan is bad? - TCCoA Forums
post #1 of 5 (permalink) Old 08-30-2007, 10:45 PM Thread Starter
The_Ghost's Avatar
I have a 94 3.8L that is not only running rough, but it gets hot. Not terribly hot, but we all know how sensitive those headgaskets are...
Anyhow, I don't ever hear the high-speed fan click on like I do with all my other cars... and this is with the windows rolled down, music off.
How can I check?
Ghost
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #2 of 5 (permalink) Old 08-30-2007, 10:53 PM
fl96thunderbird's Avatar
Send a message via Yahoo to fl96thunderbird
Turn on the A/C and high speed fan should kick on....if I'm not mistaken it is the high speed. Or you can use a jumper wire from the battery to two of the three connectors. But NOT to the ground wire. That way you will know the fan is able to spin on both speeds. Make sense?
SOLD the 96 in favor of a 97 ABS, TC, Sunroof
OEM E46 Bi-Xenon D3S
XBox 360 gamertag: POPIMP96
fl96thunderbird is offline
post #3 of 5 (permalink) Old 08-30-2007, 11:59 PM
jco1385's Avatar
happen to know which is which?
jco1385 is offline
post #4 of 5 (permalink) Old 08-31-2007, 12:01 AM
Considering its 1am no..... But can look in the morning.
post #5 of 5 (permalink) Old 08-31-2007, 01:44 AM Thread Starter
The_Ghost's Avatar
yeah the AC doesnt work on this car.
The clutch will engage for 3-4 seconds then it will stop again.
