Well it wasnt the main seal - TCCoA Forums
post #1 of 4 (permalink) Old 08-31-2007, 06:28 AM Thread Starter
I changed out the rear main seal and the front seals on the trans and its still leaking oil. Could that much oil be coming from the oil pan?
xm177 is offline
post #2 of 4 (permalink) Old 08-31-2007, 08:05 AM
jco1385's Avatar
if the rubber gasket is bad/missing, yes.
jco1385 is offline
post #3 of 4 (permalink) Old 08-31-2007, 09:33 AM
ClintD's Avatar
When you replaced the front seal did you check the front pump bearing?
If it's down to the brass It's shot.
ClintD is offline
post #4 of 4 (permalink) Old 09-05-2007, 07:26 PM Thread Starter
Yeah its trans fluid and its worse than ever. Wtf even with the bad bushing I think somethings wrong ie assembly or wrong seal to be leaking so much.
xm177 is offline
