Question about doing a compression test - TCCoA Forums
post #1 of 4 (permalink) Old 09-01-2007, 09:33 AM Thread Starter
jda95bird's Avatar
Can I just pull the #15 fuse when I do the test?
94 Thunderbird 3.8 daily driver stock with Xenon body kit and wing
95 Thunderbird 4.6 PI Explorer swap with Kooks headers, 2.5" dual exhaust, marauder converter, and Jmod
jda95bird is offline
post #2 of 4 (permalink) Old 09-03-2007, 09:59 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
i just pull the EEC fuse or fuel pump fuse. You could even just disconnect the coil wire.
-Thomas
Thomas is offline
post #3 of 4 (permalink) Old 10-29-2007, 03:51 PM
Birdman232's Avatar
-Thomas
I just pull the coil plug when i do it...
Birdman232 is offline
post #4 of 4 (permalink) Old 10-29-2007, 05:32 PM
If you just unplug the coil the you will be dumping raw fuel into the combustion chambers and exhaust, which isn't good for the cats. Either the fuel pump or PCM fuse is best.
