Cooling mods - TCCoA Forums
post #1 of 7 (permalink) Old 09-07-2007, 10:45 PM Thread Starter
JMags's Avatar
Cooling mods
My car just split its radiator at the lower mount of the fan. So obviously it needs to be replaced.
My question: is there a better rad I can bolt right in?
I thought about the 04' cobra rad but I need a trans cooling/heating section as I drive this in the winter too. Is the V8 rad any better/ does it fit?
Thanks in advance for the help all.
Black '97 XR7
Magnaflow almost true duals w/ 3" rolled tips
Transgo bucking kit w/ aux cooler
JMags is offline
post #2 of 7 (permalink) Old 09-08-2007, 09:54 AM
954.6tbird's Avatar
dang that sucks, didnt you have to replace the upper rad hose at SB6 in the comfort inn parking lot?
954.6tbird is offline
post #3 of 7 (permalink) Old 09-08-2007, 10:31 AM Thread Starter
JMags's Avatar
You bet, my cooling system seems to be taking a crap. Almost 115k miles though & that upper was original.
Black '97 XR7
JMags is offline
post #4 of 7 (permalink) Old 09-11-2007, 11:47 AM Thread Starter
JMags's Avatar
Someone has to know if the V8 rad is better & will work, come one please let me know!
Black '97 XR7
JMags is offline
post #5 of 7 (permalink) Old 09-11-2007, 12:07 PM
ClintD's Avatar
I don't know about a 97, but 91-93 the rad was the same for the 6 and 8. The only one that was different was for the supercharged engine. (Due to the inter-cooler.)
ClintD is offline
post #6 of 7 (permalink) Old 09-11-2007, 02:54 PM Thread Starter
JMags's Avatar
Not really the answer I wanted but thank you for you help.
Anyone know if the 4.6 rads are the same situation?
Black '97 XR7
JMags is offline
post #7 of 7 (permalink) Old 09-11-2007, 09:08 PM
their not the same
If you want to step it up a notch its gonna cost you. go with a griffin, but again, its gonna cost.
mn12v6x2 is offline
