02 3.8L stang engine, in a 93? - TCCoA Forums
post #1 of 19 (permalink) Old 09-13-2007, 10:53 AM Thread Starter
Question, will a 2002 mustang 3.8L engine work in a 93 Thunderbird?
I'm just talking about the long block, not the split port.
Also, does $350 sound reasonable for a 38,000 mile 2002 3.8l?
post #2 of 19 (permalink) Old 09-13-2007, 10:55 AM
jco1385's Avatar
i paid $550 for a rebuilt 97 3.8l. whole engine minus dizzy, starter and alt.
it could be done i'm sure. the work may make it not worth it tho.
jco1385 is offline
post #3 of 19 (permalink) Old 09-13-2007, 09:46 PM
$350 for the shortblock is not a bad deal. $350 for a longblock would be great.
I paid $500 for the whole engine, from catalytic converters to the serpentine belt. This one was an 04 3.9l w/ about 45K on it.
I can't remember if the 93 is a DIS system or not. If it is, and I were you, I would go all the way with the entire motor swap to split port, you will not regret the extra effort.
mn12v6x2 is offline
post #4 of 19 (permalink) Old 09-14-2007, 07:01 AM
JMags's Avatar
A 93 will have a distributer unless it is an SC car originally. The distributer from the 93 & intake on the 2002 will have an arguement about who gets to be there.
Black '97 XR7
Magnaflow almost true duals w/ 3" rolled tips
Transgo bucking kit w/ aux cooler
JMags is offline
post #5 of 19 (permalink) Old 09-14-2007, 08:53 AM
jco1385's Avatar
i dunno if this matters, but the 97 was DIS. my 94 was distributor. i took the dist. from the 94 and stuck it in the 97 w/ no problems
jco1385 is offline
post #6 of 19 (permalink) Old 09-14-2007, 09:43 AM
JMags's Avatar
You can certainly convert the car to DIS to get it out of the way, I/m pretty sure Rod (racecougar) did on his 94. Jco1385 you stayed singleport correct? So your intake manifold is the same as mine, not an interference issue there, the 2002 hangs over that area & wont clear.
Black '97 XR7
JMags is offline
post #7 of 19 (permalink) Old 09-14-2007, 09:44 AM
Not to be a smart ass here, this is a serious question - why would you want to switch to a distributor? any advantages? easier to work on or what?
mn12v6x2 is offline
post #8 of 19 (permalink) Old 09-14-2007, 09:46 AM
jco1385's Avatar
no, engine didnt have the coil packs when i bought it. i already had the dist. it's a money thing. works the same IMO
i also don't know anything about the DIS system. i'm old school when it comes to working on cars. i know you're like "22 years old can't be old school..." my first car was a 78 bird. and my dads cars are all carbed. thats old school to me.
jco1385 is offline
post #9 of 19 (permalink) Old 09-14-2007, 09:56 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
nick, is this for kris's bird? if he can locate a bare 5.0 block, ill sell him all the internals and heads cheap. i even have the intakes and valve covers, too, as well as some other small parts. they are takng up space here. lemme know or have him call me.
2014 GT
1990 300ZX TT
big mike is offline
post #10 of 19 (permalink) Old 09-14-2007, 09:57 AM Thread Starter
yeah, its $350 for the whole motor....
my question is, will just the long block work?
minus the split port intake, and minus the stang accessories.
Just trying to get the car back on the road, and don't really care about an intake swap right now...
Yeas the 93 has a dizzy in it now....can the 02 3.8L accept a dizzy?
post #11 of 19 (permalink) Old 09-14-2007, 09:59 AM Thread Starter
yes, this is for Kris' bird.....and he already has another 5.0 block, but just wants to get the car back on the road asap.
Heck, if we were going to go a V8 swap, then he would more than likely put my 4.6 and 4r70w in..
post #12 of 19 (permalink) Old 09-14-2007, 10:05 AM
Motorboatin' SOB
big mike's Avatar
nick, if you use the split port heads, you gotta use the intake to go with it. only the shortblock would be useful. im pretty sure the 02's are distributorless, but if he reuses his wiring, i think it can be done with a distributor.
2014 GT
1990 300ZX TT
big mike is offline
post #13 of 19 (permalink) Old 09-14-2007, 10:07 AM Thread Starter
really...hmmm....well, I guess let me do some searching, and see about swapping to a split port..
post #14 of 19 (permalink) Old 09-14-2007, 10:15 AM
JMags's Avatar
Fuel system is a concern as well I think. '02 should be returnless, need to swap the rails & make the fuel lines longer IIRC
Black '97 XR7
JMags is offline
post #15 of 19 (permalink) Old 09-14-2007, 02:42 PM
Only if he's doing a split port swap.
post #16 of 19 (permalink) Old 09-15-2007, 02:50 AM
The_Ghost's Avatar
keep the split port intake.
do it right and do the splitport swap since you're already buying the motor.
best,
ghost
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #17 of 19 (permalink) Old 09-16-2007, 09:57 PM
best,
ghost
I couldn't agree more!
It will take you a little longer, and a lttle more planning, especially with the DIS vs. distributor issues, but it will be worth it.
And if I remember correctly (youll have to check this), the problem isn't with the distributor hitting the intake, I thought it would be the EGR tube and mount, or the water lines from the pump. I really can't say, but there has got to be a reasonable change to make the dizzy work.
mn12v6x2 is offline
post #18 of 19 (permalink) Old 09-17-2007, 06:09 AM
The interference issue with a distributor on a 3.8L Splitport is with the EGR valve and the fuel rail. The intake itself clears.
If you're interested in swapping to DIS, a quick search will turn up the wiring diagram that I made up for the swap.
-Rod
post #19 of 19 (permalink) Old 09-17-2007, 09:51 AM Thread Starter
not interested in the split port swap......just need to get the car moving, probably just to sell it..
