MM Installation Question - TCCoA Forums
post #1 of 11 (permalink) Old 09-13-2007, 11:38 AM Thread Starter
Ok I ordered a set of motor mounts from supercoupeperformance.com and my question is: After I jack up the whole car then jack up the engine, will the old motor mounts be a direct swap with the new motor mounts? As in i dont need anything else before attempting this?
bmsirhc1313 is offline
post #2 of 11 (permalink) Old 09-13-2007, 11:50 AM
jco1385's Avatar
it should be a direct swap.
jco1385 is offline
post #3 of 11 (permalink) Old 09-13-2007, 09:54 PM
just do it man!
you got everything you need except a 12 pack and good selection of curse words!
mn12v6x2 is offline
post #4 of 11 (permalink) Old 09-14-2007, 08:54 AM
jco1385's Avatar
curse words optional. 12 pack not so much...
jco1385 is offline
post #5 of 11 (permalink) Old 09-20-2007, 05:19 PM Thread Starter
Originally Posted by mn12v6x2 View Post
12 pack
post #6 of 11 (permalink) Old 09-20-2007, 06:51 PM
When i did mine there were ALOT of curse words lol
Birddude93LX is offline
post #7 of 11 (permalink) Old 09-21-2007, 10:28 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
you just need to jack up the engine little bit to get the weight off the mounts. then remove the one long bolt. you will need a long extension and a breaker bar.
2014 GT
1990 300ZX TT
big mike is offline
post #8 of 11 (permalink) Old 09-21-2007, 10:52 AM
Traveler's Avatar
How do the mounts attach to the K-Member exactly? I had the engine out of my car, but didn't really pay attention to the mounts as I wasn't going to replace them anyway.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #9 of 11 (permalink) Old 09-21-2007, 10:58 AM
Motorboatin' SOB
big mike's Avatar
there's three pieces to the mounts. there's an upper and lower bracket with the actual mount in between. the lower bracket has two holes that the long bolt threads into. the lower bracket also fits over a metal "box" that is part of the k-member. this "box" has holes in it that also accept the same long bolt.
2014 GT
1990 300ZX TT
big mike is offline
post #10 of 11 (permalink) Old 09-22-2007, 04:53 AM
392Bird's Avatar
Here is a picture of a 5.0 mount.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #11 of 11 (permalink) Old 09-22-2007, 09:36 PM
Originally Posted by bmsirhc1313 View Post
alright, I got it, a few 12 packs!
That's not at all what the 3.8 mounts look like, I dont know about the 4.6 though. similar but not the same.
i guess the bottom part is the same, but the plate that attaches to the block is different.
mn12v6x2 is offline
