Won't Shift into Park - TCCoA Forums
post #1 of 2 (permalink) Old 09-13-2007, 06:01 PM Thread Starter
Hello, my thunderbird will not shift into park. It can shift into any gear besides that, and the car's shift handle is not blocked/obstructed. I just wonder what is broken/ if it's worth fixing. Thanks!
TBirdLXNewbie is offline
post #2 of 2 (permalink) Old 09-13-2007, 09:48 PM
you'll have to get up underneath the drivers side, and look on the side of the tranny, you can see all the external items from there, and may be able to see whats causing the problem. If nothing there, I would keep asking, I think there are a few things like ignition and other things, maybe brake peddle obstructions that can cause that same issue.
good luck
mn12v6x2 is offline
