HELP!!! Cooling system nightmares. - TCCoA Forums
post #1 of 14 (permalink) Old 09-26-2007, 08:26 PM Thread Starter
Exclamation HELP!!! Cooling system nightmares.
Anyone who has been following the post over the last several months know that my 95 lx has been nothing but a fu**ing nightmare for me. Well I am having a problem keeping it running cool now. I will take it out for a drive and the temp gauge will bury itself all the way on the hot side. When I stop and look under the hood coolant is boiling out of the coolant resevoir. I have replaced the radiator, water pump, thermostat, fan, and radiator cap and still no luck . I read somewhere on here where you can fill the coolant system thru the vent plug and that is what i did . Could that have caused the problem? If so what can I do to fix it? Any ideas at all? Thanks for any help.
bubbaking is offline
post #2 of 14 (permalink) Old 09-26-2007, 10:02 PM
thewishkah's Avatar
Send a message via AIM to thewishkah
Probably already thought of it but maybe the new t-stat is no good or maybe its in backwards Im not saying thats def if but it could happen.
thewishkah is offline
post #3 of 14 (permalink) Old 09-27-2007, 06:47 AM
I hate to be the bearer of bad news but...
Do a search for blown head gaskets .
It sounds like they are in the process of going.
badcat92 is offline
post #4 of 14 (permalink) Old 09-27-2007, 10:12 AM
jco1385's Avatar
and check the fan to make sure it still works.
jco1385 is offline
post #5 of 14 (permalink) Old 09-27-2007, 08:25 PM
That is exactly what happened to my car when the head gasket went... $2000.00 later... it was fixed...
foobarbigtime is offline
post #6 of 14 (permalink) Old 09-27-2007, 09:06 PM
jco1385's Avatar
my hg's went. $600 and a new engine here it is....
jco1385 is offline
post #7 of 14 (permalink) Old 09-28-2007, 05:42 PM Thread Starter
brand new head gaskets, and the fan is a clutch fan
post #8 of 14 (permalink) Old 09-28-2007, 08:19 PM
94fastbird's Avatar
Send a message via MSN to 94fastbird
your heater core could be plugged. do radaitor flush too.
94fastbird is offline
post #9 of 14 (permalink) Old 10-04-2007, 08:39 AM
Did you figure it out yet?
post #10 of 14 (permalink) Old 10-04-2007, 09:00 AM
jco1385's Avatar
new hg's could go bad too if not done right
jco1385 is offline
post #11 of 14 (permalink) Old 10-06-2007, 10:13 PM Thread Starter
have not figured it out yet, have not had time to mess with it due to work schedule. I dont think it is the hg due to the fact there is no signs what so ever of leakage. No oil in the coolant and vice versa. Just to ease my mind which way should the thermostat go? Does the spring side go towards the rad or the motor?
post #12 of 14 (permalink) Old 10-07-2007, 10:07 AM
It is nice
motor
91CougarLS is offline
post #13 of 14 (permalink) Old 10-07-2007, 09:36 PM Thread Starter
thats what I thought, looks like i might be stripping it down and retorquing the heads. Anyone think that could be the problem?
post #14 of 14 (permalink) Old 10-09-2007, 02:53 PM
white lincoln's Avatar
Ouch! My car is not even worth that! $300 and it was done.
white lincoln is offline
