charging woes - TCCoA Forums
post #1 of 2 (permalink) Old 10-04-2007, 05:30 PM Thread Starter
charging woes
I have A 89 lx 3.8 will not charge replaced alt brushes&regulator found burnt fuse link at starter relay is this cause of no charge thank 4 input
mrlucky1128 is offline
post #2 of 2 (permalink) Old 10-09-2007, 04:49 PM
4.3Lcougar's Avatar
if you have a short in the system anywhere in the battery circuit, it will naturally go to the least resistance path.... a ground. so if you found a bad fuse change it and go from there.
1985 THUNDERBIRD CFI 5.0L..
4.3Lcougar is offline
