Will a 1992 3.8 work in a 96? - TCCoA Forums
post #1 of 20 (permalink) Old 10-23-2007, 09:51 AM Thread Starter
RCReevesPhotography's Avatar
Question Will a 1992 3.8 work in a 96?
I have a 1992 3.8 car I'm parting out and the engine runs like a top, a friend of mine has a 1996 3.8 car he would like to sale me for almost nothing and the only thing wrong with it is the motor is shot. What would I need to do to make my engine work in that car?
RCReevesPhotography is offline
post #2 of 20 (permalink) Old 10-23-2007, 10:28 AM
jco1385's Avatar
wiring, and probably eec-iv swap to eec
jco1385 is offline
post #3 of 20 (permalink) Old 10-23-2007, 10:37 AM
greencurse's Avatar
i think you could just swap all sensors/wiring from the 96 engine on the 92. Its the same engine after all wether its using cans or obdII.
1997 Thunderbird LX, 4.6L, Performance White.
3.27 TL, 300hp J-Mod, Mid-Mount Magnaflow w/2.25" True Duals to 3" Magnaflow 15* Slash Cut Tips, PI Intake,
FR500 Steering Wheel, FRPP Wires, 180* T-Stat, 22C Plugs, Cobra Vert Rears, RSTB, SC "L" Braces. 175k and still flying!
greencurse is offline
post #4 of 20 (permalink) Old 10-23-2007, 11:17 AM
jco1385's Avatar
i put a 97 in my 94 w/ minor modification. just had to swap wiring harness an a few sensors and such. and i made it a dist instead of DIS
jco1385 is offline
post #5 of 20 (permalink) Old 10-23-2007, 12:59 PM
Traveler's Avatar
Why would you want to put a 92 3.8 in a 96? By 96, the head gasket thing was pretty much taken care of.
If he's selling it to you for near nothing, just find a good salvage 96 or newer 3.8 and put that in. Just my .02 worth.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #6 of 20 (permalink) Old 10-23-2007, 06:44 PM
decipha's Avatar
if your gonna go the hassle of putting in a 3.8 at least make it worthwhile with a s/c
O&E Speed Shop - 2333 Aberdeen St. Kenner, LA
EFI Calibrator - decipha @ EFIDynoTuning
http://www.efidynotuning.com/tune.htm
decipha is offline
post #7 of 20 (permalink) Old 10-26-2007, 08:54 PM
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
yea i wouldn't put that 92 in there.
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #8 of 20 (permalink) Old 10-26-2007, 09:03 PM
You can swap the longblock over, just transfer anything that's different on the 96 motor over to the 92 motor. Also while you have the motor out, it would be a good idea to replace the head gaskets, and use head studs so you won't have any problems with them in the future.
post #9 of 20 (permalink) Old 10-26-2007, 10:00 PM
You can't swap the long block over. The heads and lower intake are different between the two motors.
post #10 of 20 (permalink) Old 10-26-2007, 10:32 PM
The heads have a thicker deck in the 96, but that was just to ease the head gasket problem. I'm pretty sure the lower intake is the same on all singleport 3.8s.
post #11 of 20 (permalink) Old 10-26-2007, 11:05 PM
Nope. 96-97 have 12 bolts (6mm) while 95-earlier have 14 bolts (8mm).
post #12 of 20 (permalink) Old 10-26-2007, 11:37 PM
jco1385's Avatar
true. def. not the same. the upper is, not lower. front cover and w/p are different too.
jco1385 is offline
post #13 of 20 (permalink) Old 10-27-2007, 12:09 AM
Also true, I just didn't think to mention it since the long block was being discussed and those components aren't part of that.
post #14 of 20 (permalink) Old 10-27-2007, 07:36 AM
I didn't know that. So he could still swap the motor, he would just have to leave the lower intake from the 92 on it, right?
post #15 of 20 (permalink) Old 10-27-2007, 02:40 PM
Yeah that would work, but then he'd lose the benefit of the better head design.
post #16 of 20 (permalink) Old 10-27-2007, 09:53 PM
He should just drive down here and take mine. works perfect...He'd have to pull it or tow the whole thing back to Ohio...starts right up and even still drives..
Plankster is offline
post #17 of 20 (permalink) Old 10-27-2007, 10:11 PM
Pedal Faster
Josh_Keady's Avatar
Remember, if you go from '96 to '92, you have to not only swap the wiring harness and EEC, you have to have go to an AOD tranny.
Josh Keady
Josh_Keady is offline
post #18 of 20 (permalink) Old 10-28-2007, 12:07 AM
No, you don't have to do any of that. You reuse all the 96 wiring, computer, and trans. You just have to use the motor, heads, and lower intake from the 92.
post #19 of 20 (permalink) Old 11-08-2007, 04:06 PM
Gary Bitzer's Avatar
hah....taken care of, ive got a 96 with 140k and it blows AF out the tailpipes just like the old ones did JUNK!!! always was and always will be
The Collection:
1988 Thunderbird Turbo Coupe; 1989 Thunderbird SC; 1993 Thunderbird SC; 1993 Thunderbird LX 5.0; 1994 Thunderbird SC 5spd; 1995 Cougar XR7 4.6; 1995 Thunderbird 4.6; 1996 Cougar XR7 3.8
The Search begins;
1990 35th Anniversary SC very low miles, auto, loaded
1998 Lincoln Mark VIII Collectors Edition
Gary Bitzer is offline
post #20 of 20 (permalink) Old 11-08-2007, 11:19 PM
Traveler's Avatar
My sister has my old 97 3.8 with 172,000 miles on it (and counting) No engine trouble to date (other than cleaning the MAF, etc.) No smoke, no AF, gets good gas mileage. Heads have never been off the car.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
