head gasket question - TCCoA Forums
post #1 of 4 (permalink) Old 11-09-2007, 12:02 PM Thread Starter
Gary Bitzer's Avatar
is it normal for these engines to have a blown intake gasket along with the head gaskets? i tore down the engine in my 96 last night and it looked to me like the problem was the intake gasket, water blowing out tailpipes and some in the oil. i didnt take the heads off yet but im wondering if the gaskets are even bad.
The Collection:
1988 Thunderbird Turbo Coupe; 1989 Thunderbird SC; 1993 Thunderbird SC; 1993 Thunderbird LX 5.0; 1994 Thunderbird SC 5spd; 1995 Cougar XR7 4.6; 1995 Thunderbird 4.6; 1996 Cougar XR7 3.8
The Search begins;
1990 35th Anniversary SC very low miles, auto, loaded
1998 Lincoln Mark VIII Collectors Edition
Gary Bitzer is offline
post #2 of 4 (permalink) Old 11-09-2007, 02:20 PM
No, it's not that common.
post #3 of 4 (permalink) Old 11-14-2007, 03:00 PM
Old_coot's Avatar
Send a message via Yahoo to Old_coot
under the circumstances I might run a compression check and if it comes out good I would invest in an intake gasket set before I pulled the heads---but if the compression test is bad then go ahead with the tear down.............Dan
Old_coot is offline
post #4 of 4 (permalink) Old 11-28-2007, 09:13 AM
white lincoln's Avatar
If you have the intake out already, keep going and do the heads as well. I did the heads and all and did not do the water pump when I was looking at it. Now I wish I would have when I had the engine apart.
white lincoln is offline
