One cylinder on my 3.8 is going, new engine? - TCCoA Forums
post #1 of 16 (permalink) Old 11-11-2007, 10:11 AM Thread Starter
MeanGene's Avatar
I have one cylinder that is on the way out. Funny that it's on the other bank which blew the head gasket. I found a brand new 3.8 at a locl parts house for $2000.00. Should I by the brand new engine or do somethng else with this?
MeanGene is offline
post #2 of 16 (permalink) Old 11-11-2007, 02:45 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
What about this cylinder is "going out"? Compression? burnt valve? bad spark plug? Need more info.
Secondly, what year is this car? Is it a 1988 like your description says?
$2000???? you could buy another car for that much! I understand its an aftermarket rebuilt engine, but that is too much to spend on these cars. I would try and find a used 96-98 shortblock. Strong buggers, and a direct swap.
-Thomas
Thomas is offline
post #3 of 16 (permalink) Old 11-11-2007, 03:28 PM
For $2,000 you could find a 96/97 with a 4.6L. Don't waste money rebuilding the 3.8L but fix it if it's something simple, otherwise try to find a good, cheap used one.
post #4 of 16 (permalink) Old 11-11-2007, 08:43 PM Thread Starter
MeanGene's Avatar
Yeah, it's an 88 with the 3.8. The engine I was referring to is not a rebuilt, but a brand new factory engine. I would like more info on the 4.6L direct swap. Any links would be helpful. I would like to keep the car. I have other, newer vechiles, but I like driving the T-bird for some reason.
MeanGene is offline
post #5 of 16 (permalink) Old 11-11-2007, 08:56 PM
For 2K you could buy a whole new T-Bird and part out yours to make your new rider better.
KansasCity is offline
post #6 of 16 (permalink) Old 11-12-2007, 12:16 AM
FYI a "brand new" factory rebuild is just a remanufactured engine. Ford doesn't make NEW 3.8's for these cars anymore.
post #7 of 16 (permalink) Old 11-12-2007, 01:18 AM Thread Starter
MeanGene's Avatar
I happen to live very close to a Hawaii Racing outlet. I was just walking through the store and asked about a 3.8 sitting in an engine stand. I asked how much and they said around 2G's, I asked why so much, they said because it was a new engine not a re-built. But, here is the link. about half way down. Not sure what they meant, but if it's not a whole heck of a lot of work, I would be interested in something with a bit more power.
MeanGene is offline
post #8 of 16 (permalink) Old 11-12-2007, 04:29 AM
Oh it's an NOS engine. I thought it was from a dealer. I didn't read it was from a parts house. Either way it's a total rip.
post #9 of 16 (permalink) Old 11-12-2007, 07:51 AM
jco1385's Avatar
yeah, def too much. and that looks like the older intake, like pre-96. maybe the heads are different
jco1385 is offline
post #10 of 16 (permalink) Old 11-12-2007, 07:52 AM
jco1385's Avatar
:double post:
jco1385 is offline
post #11 of 16 (permalink) Old 11-13-2007, 12:42 AM Thread Starter
MeanGene's Avatar
So if you were in my shoes, what would you do?
MeanGene is offline
post #12 of 16 (permalink) Old 11-13-2007, 01:21 AM
greencurse's Avatar
sell the car you have now and buy an equal year Turbo Coupe or an early SC or a 96-7 4.6 LX.
1997 Thunderbird LX, 4.6L, Performance White.
3.27 TL, 300hp J-Mod, Mid-Mount Magnaflow w/2.25" True Duals to 3" Magnaflow 15* Slash Cut Tips, PI Intake,
FR500 Steering Wheel, FRPP Wires, 180* T-Stat, 22C Plugs, Cobra Vert Rears, RSTB, SC "L" Braces. 175k and still flying!
greencurse is offline
post #13 of 16 (permalink) Old 11-13-2007, 02:58 AM
decipha's Avatar
buy a s/c don't settle for anything less
O&E Speed Shop - 2333 Aberdeen St. Kenner, LA
EFI Calibrator - decipha @ EFIDynoTuning
http://www.efidynotuning.com/tune.htm
decipha is offline
post #14 of 16 (permalink) Old 11-16-2007, 02:06 PM
PCD
Confirmed V6 Nut
MeanGene, you don't say what you have for a budget. Maybe you ought to buy my daughter's 88 T-Bird for spares and the running engine. But, then I'd have to find her another car.
PCD is offline
post #15 of 16 (permalink) Old 11-16-2007, 03:49 PM
LOLA's Avatar
5.0 is the way to go.
LOLA is offline
post #16 of 16 (permalink) Old 12-12-2007, 01:27 PM
Be careful
MeanGene,
It would useful to know more about the fsailure of the one cylinder. I thought my 94 3.8 had a bad cylinder too- and I'd had the head gaskets done 9,000 miles ago, but it turned out I'd put too much tension on the spark plug wires and one had pulled the boot and connector clip off the wire!
Look into the whole siuation with engine, but at the $2,000 level for the engine plus labour- $!,200? to do the swap, I suspect you may be better off as others have mentioned and just start with another car with a good engine. Ford seem to have sorted the 3.8 for 96-97 but also, you could switch to the 4.6, which seems to be a really good engine- very smooth and about 60 additional HP.
Cheers,
Bambi B
1994 Thunderbird LX 3.8 (106,000)
1994 Lincoln MK VIII (58,000)
Bambi B is offline
