torque specs for 3.8 n/a cylinder heads? - TCCoA Forums
post #1 of 2 (permalink) Old 11-11-2007, 08:51 PM Thread Starter
Gary Bitzer's Avatar
anyone have these, i have 2 ford repair manuals and its not in there or i cant find it. i found one part where it says one half turn after contact
The Collection:
1988 Thunderbird Turbo Coupe; 1989 Thunderbird SC; 1993 Thunderbird SC; 1993 Thunderbird LX 5.0; 1994 Thunderbird SC 5spd; 1995 Cougar XR7 4.6; 1995 Thunderbird 4.6; 1996 Cougar XR7 3.8
The Search begins;
1990 35th Anniversary SC very low miles, auto, loaded
1998 Lincoln Mark VIII Collectors Edition
Gary Bitzer is offline
post #2 of 2 (permalink) Old 11-11-2007, 09:20 PM
ClintD's Avatar
Cylinder Head Bolt Tighten in (4) steps:
Step 1. Tighten bolts in sequence shown to: 50 Nm (37 lb-ft) 60 Nm
(45 lb-ft) 70 Nm (52 lb-ft) 80 Nm (59 lb-ft)
Step 2. a) Back off all bolts one at a time 2-3 revolutions and
retighten in numerical sequence as follows:
Step 3. Long Bolts: Tighten to 15-25 Nm (11-18 lb-ft) Rotate an
additional 85-95 degrees Go to next bolt in sequence
Step 4. Short Bolts: Tighten to 10-20 Nm (7-15 lb-ft) Rotate an
additional 85-95 degrees Go to next bolt in sequence.
ClintD is offline
