8.8 in lx? - TCCoA Forums
post #1 of 11 (permalink) Old 11-23-2007, 01:30 PM Thread Starter
8.8 in lx?
i looked at my rear end the other day, just curious..
anyways, 8.8 is stamped on the bottom right side of the differential
does that mean it's an 8.8 rear end (it is a 3.8 LX), or do they all have 8.8 stamped on them?
1995 Thunderbird Project ThunderSnake
1987 Mercury Cougar 2.3L Turbo 5 Speed DD
josh_marotte is offline
post #2 of 11 (permalink) Old 11-23-2007, 01:42 PM
Mark M. TCCoA VP's Avatar
Do you have antilock brakes? I seem to remember if you ordered antilock brakes you got the 8.8 dif. I could be wrong.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #3 of 11 (permalink) Old 11-23-2007, 02:32 PM
ClintD's Avatar
It's a 8.8 buddy. Now through some 3.73's in there and have some fun.
ClintD is offline
post #4 of 11 (permalink) Old 11-23-2007, 03:16 PM
Yep, the 8.8" was an option on the 3.8L's. My 94 3.8L LX came with the 8.8".
-Rod
post #5 of 11 (permalink) Old 11-23-2007, 03:43 PM
LOLA's Avatar
That's what I'm doing. Then it will be ready for the 347 a year or so down the road.
LOLA is offline
post #6 of 11 (permalink) Old 11-24-2007, 02:41 PM
Do we have a door jam label that would tell us if we have antilock brakes, 7.5 or 8.8?
dribrednuht is offline
post #7 of 11 (permalink) Old 11-24-2007, 03:22 PM
The certification label does have axle type (AXLE) and brake type (BRK) on it. The axle code tells you the ratio and whether its conventional or trak-loc, but not the size.
AXLE
1997
5 = conventional 3.27
E = trak-loc 3.27
BRK 1997
1 = 4 wheel disc
4 = 4 wheel disc w/ ABS
A = front disc rear drum
But do you really need to look up codes to tell if you have ABS or not?
Southpaw is offline
post #8 of 11 (permalink) Old 11-26-2007, 08:54 PM
The 8.8 housing is more squared off than the 7.5 housing if you look at it from the rear. I just bought a rust free 95 LX 3.8L which has 4wheel disc/abs and it has the 8.8 , My 96' with 4wheel disc/abs came with a 7.5 from the factory.
rancherlee is offline
post #9 of 11 (permalink) Old 11-26-2007, 08:57 PM
95xbird's Avatar
My 94 3.8 I used to own had an 8.8 with a 3L08.That thing did better donuts than my PI car!
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #10 of 11 (permalink) Old 11-26-2007, 09:37 PM
ClintD's Avatar
I went to a junk yard today in wrightstown today and looked at 7 mn12's.
no track-loc's and only one had a 7.5.
It was actually the first 7.5 I've seen in person.
ClintD is offline
post #11 of 11 (permalink) Old 11-26-2007, 09:48 PM
Here's what you're looking for.
