coolant pipe name? - TCCoA Forums
post #1 of 9 (permalink) Old 11-26-2007, 11:04 PM Thread Starter
coolant pipe name?
well on my 93 3.8L over my passenger side valve cover right under my intake tube there is a metal section of pipe that carries antifreeze with what appears to be sensor screwed into it.
anyone know the name of that section of pipe? mine seems ot have rusted a pin hole size just enough to leak and needs to be replaced.
would i need to go to Ford for it? our would NAPPA/Autozone/Advance Auto Parts carry it?
thanks guys
Dean
1993 3.8L Tbird----sold
1994 4.6L Tbird----sold
1995 Mark VIII----sold
2004 Mustang GT----sold
2003 Mach 1----current
smitty2919 is offline
post #2 of 9 (permalink) Old 11-26-2007, 11:21 PM
ClintD's Avatar
I know exactly what you're talking about, but I doubt you will get one new.
It's a coolant crossover tube and I had to get one from the junk yard.
Dealer said it was a non wearing item and it's discontinued.
ClintD is offline
post #3 of 9 (permalink) Old 11-27-2007, 08:47 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
sounds like the heater core tube.
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 9 (permalink) Old 11-27-2007, 03:31 PM
jco1385's Avatar
i think i may have one from my 94 if you're interested
jco1385 is offline
post #5 of 9 (permalink) Old 11-27-2007, 03:38 PM
decipha's Avatar
i don't know exactly what your talking about but if possible your best bet may be to cut a section of the pipe out and substitue it with a coolant hose
O&E Speed Shop - 2333 Aberdeen St. Kenner, LA
EFI Calibrator - decipha @ EFIDynoTuning
http://www.efidynotuning.com/tune.htm
decipha is offline
post #6 of 9 (permalink) Old 11-27-2007, 08:16 PM
That tube was around in 86 on the CFI 3.8. In fact, there were two of them, one on each side of the 123 valve cover. And yes, those non-wearing items started leaking like a seive on my 3.8 too. I deleted them completely, and just ran rubber hose all the way to the heater.
You said, however, that yours has a sensor in it? This, I would have to see. The ECT is normally in a tee on or near the t-stat housing, but yes, it is in the heater core plumbing. I'm curious if Ford moved it on different makes of the 3.8. I didn't even notice where the ECT was on my son's 90 model.
1970 VW Beetle Baja
1986 Thunderbird 3.8L, EEC-IV, OBD-I
1992 F-150 5.0L, M5OD, 3.08 dif, EEC-IV OBD-I
Old_Paint is offline
post #7 of 9 (permalink) Old 11-27-2007, 08:55 PM
This sensor isn't for the PCM, it's for the Semi-Automatic Temperature Control.
post #8 of 9 (permalink) Old 11-28-2007, 12:33 AM
ClintD's Avatar
You can just leave the wire disconnected.
It's for the auto-climate control so the blower wont blow full blast if the engine isn't hot enough to produce heat.
ClintD is offline
post #9 of 9 (permalink) Old 12-01-2007, 04:20 PM Thread Starter
would there be a way to maybe weld it? anyone know how thick the metal is, i was thinking maybe taking it off, snading and cleaing it then maybe weld it.
otherwise, yes i was thinking of replacinf it with a seciont of tube, but then i saw the sensor attached.
