K&N Air Filters - TCCoA Forums
post #1 of 8 (permalink) Old 12-13-2007, 10:21 PM Thread Starter
K&N Air Filters
Has anyone had problems with the oil from a k&n air filter getting onto the mass airflow sensor.I've read about it in other forums(other makes and models)causing problems but haven't read anything about it affecting the 3.8 ,Ithought i'd ask before buying one,thanks.Dave
dcruit95coug is offline
post #2 of 8 (permalink) Old 12-13-2007, 10:52 PM
This is one of the most common problems on here. It will affect any car with a MAF sensor without regard for a particular engine.
post #3 of 8 (permalink) Old 12-14-2007, 12:48 AM
Kelsey Smith's Avatar
Send a message via MSN to Kelsey Smith
If they're over-oiled, then yeah, I could see how they could cause a problem, but I've been running a K&N for years, with no issues, lightly oiled, both in a 3.8 and in a 4.6, with no problems
"WHAT CONE?!?!
1997 T-Bird Sport, 'Interceptor' (12 ESP 2008-2012)- CAI, 2.25 duals, Flowmaster 40 series, Clear corners, BBK 70mm Throttle Body, TrickFlow upper intake, PI Intake, BBK adjustable fuel pressure regulator, LE stripes, Bullitt-style gauge faces. 18x9 wheels, Sniper tuned, 3,620 pounds
1991 Ford F250 - Air restrictor delete. Cat delete.
1991 T-Bird 'Interceptor II' (12 CP 2013-) - Race-prep, Full custom "interior", Carb'd 302, Trick Flow twisted wedge heads, stage 1 cam, Custom Koni coil-overs front, Koni yellows rear, Cobra front brakes, fuel cell, 18X9 wheels, 275/30 Hoosier A6, 4.11 T-Lok. 3000 pounds
2004 Toyota Solara SE - V6, Sport package, Muffler delete, 17X7 wheels, 235/50 Conti ExtremeContact DWS
Kelsey Smith is offline
post #4 of 8 (permalink) Old 12-14-2007, 09:51 PM
Even if they are lightly oiled, you'll eventually get some oil/grime accumulation on the MAF. At the same time, there are plenty of stock filtered cars out there that accumulate enough gunk on the MAF to set off the CEL. Either way, I clean the MAF sensors on my vehicles about once a year. It's easy enough to do.
That's just my take on the matter.
-Rod
post #5 of 8 (permalink) Old 12-14-2007, 10:41 PM
-Rod
Lightly oil the filter and clean your MAF sensor about once a year and you'll be fine.
post #6 of 8 (permalink) Old 12-15-2007, 12:37 AM
I agree My bird has had one for nearly 6 months and not one issue.
post #7 of 8 (permalink) Old 12-15-2007, 03:08 AM
Moderator & Teksid Whore
guitar maestro's Avatar
why not just go with one of fram's new non-oiled washable air filters?.......not that any aftermarket air filter will gain you any hp on a properly maintained 3.8, but if you absolutely have to have a reuseable filter, might as well save a bit on it instead of buying an unnecessarily high-flowing oiled type filter
guitar maestro is offline
post #8 of 8 (permalink) Old 12-15-2007, 03:56 PM
i bought my k&n panel filter for a dollar at the junkyard, people having problems with their mafs are the same people who are over oiling the filters.
