replacing spark plug wires? - TCCoA Forums
post #1 of 9 (permalink) Old 01-14-2008, 08:05 PM Thread Starter
Blindloser1080's Avatar
I did a spark plug change yesterday the birdie, and I was wondering, when do you know when your plug wires are done for? How do you know it's time to change em out? I looked at mine, and I believe they are the original ones they came with, they have the Ford logo on the boot My 3.8 birdie is sittin right round 122K miles on her.
Thanks!
Josh
Blindloser1080 is offline
post #2 of 9 (permalink) Old 01-14-2008, 09:42 PM
The most common indicator is that the car will misfire or bog down when under load. The engine can also run a bit rough if the spark being delivered to one, a couple, or all cylinders is weak, and fuel economy and power will decrease.
post #3 of 9 (permalink) Old 01-15-2008, 04:19 PM
they are supposed to be changed every 60,000 - 100,000 miles, or so ford recommends, obviously change them if they arc, or if any of the insulation is showing.
post #4 of 9 (permalink) Old 01-15-2008, 04:33 PM
Baby Huey
warmaster259's Avatar
Measure the resistance across them with a Multimeter, if it is high then they need to be replaced.
Jim
warmaster259 is offline
post #5 of 9 (permalink) Old 01-27-2008, 06:01 PM
EuroBird's Avatar
Send a message via MSN to EuroBird
Mayhaps a slightly dumb question,
but how do I measure ohms with my meter? And what's a high reading and what's a low reading, and more importantly what's the cut off point for no good wires.
TIA
90 Chevy c1500
78 Jag xj6
78 Volvo 245 b230fk turbo
72 VW Beetle Subaru EJ20
72 MGB GM v6/t5
67 Volvo Amazon Wagon
65 Volvo Duette
64 Volvo PV544
62 Volvo Amazon Coupe
56 Ford Popular 302/AODE
52 Chevy 3100, 454/700r4
EuroBird is offline
post #6 of 9 (permalink) Old 01-27-2008, 09:21 PM
Old plug wires will also get stiff and lose their flexibility.
There are some good alternative choices to the stock wires listed in the TECH ARTICLES.
I run the 8.5mm Magnacor wires and am very pleased with them.
I'd say on a 3.8 engine it wouldn't make much difference, if any, which wires you went with. I'd say based on the tech articles any resistance much more than 9,000 ohms is unacceptable and the wires should be replaced.
The lower the resistance the better.
post #7 of 9 (permalink) Old 01-28-2008, 02:08 AM
Keep in mind that resistance will vary by length of the wire, so longer ones will have higher resistance.
post #8 of 9 (permalink) Old 01-30-2008, 01:53 PM
PCD
Confirmed V6 Nut
Just get a set of FRPP wires for a 3.8 Mustang and you'll be good to go for a long time.
PCD is offline
post #9 of 9 (permalink) Old 03-30-2008, 10:56 AM
You can also wait till its dark. Start your car with hood up. With a MIST bottle mist the wire area... If you see a lightshow, time for a change.
emj1s is offline
