ARP torque specs question - TCCoA Forums
post #1 of 6 (permalink) Old 01-16-2008, 09:59 AM Thread Starter
LOLA's Avatar
I will be replacing the head haskets in the spring as well as putting on a pair of rebuilt heads. I ordered the ARP set for the Chevy 2.8 as most have recomemded.
Now my question. Do I use the torque specs that are in the Chilton's manual or are there different specs since the ARP are not torque to yeild?
LOLA is offline
post #2 of 6 (permalink) Old 01-16-2008, 10:07 AM
ALWAYS use the torque specifications/procedures provided by the bolt manufacturer (IMHO).
Also, IIRC, ARP says to use their lube since oil may change the torque specs.
Just my .02.
69 F100 LWB w/460 Engine
post #3 of 6 (permalink) Old 01-16-2008, 12:03 PM Thread Starter
LOLA's Avatar
Hopefully Bg Mike will chime in. I know he has used these on his 3.8
LOLA is offline
post #4 of 6 (permalink) Old 01-16-2008, 03:42 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
chime
its been a few years since i have done headgaskets. use arp's torque specs and get some of their moly lube. refer to your manual to see if any of the head bolt holes need sealant applied to the bottom threads of the stud. i think some of the bolts protrude into water jackets.
2014 GT
1990 300ZX TT
big mike is offline
post #5 of 6 (permalink) Old 01-16-2008, 04:03 PM Thread Starter
LOLA's Avatar
Thank you Mike.
When I did thr right side in Aug '05 I do not recall the Chilton's saying anything about needing sealant but I will double check that. The bolts are on my door step waitng for me when I get home.
LOLA is offline
post #6 of 6 (permalink) Old 01-29-2008, 06:10 PM
I have mine torqued at 75lb/ft, but some have gone as high as 110lb/ft. Those people are also running 20-30psi.
Wicked6 is offline
