3.8 left side of engine noise - TCCoA Forums
post #1 of 4 (permalink) Old 01-28-2008, 04:53 PM Thread Starter
I have a carburated 3.8l in my 87 bird and a funky sound is coming from the left side valve cover... like a squeeking sound i hope it isnt expensive and i dont need a new motor and if i doo need one where can i get a 3.8 for my car n houw much thanks!
Riverheadracer is offline
post #2 of 4 (permalink) Old 01-29-2008, 09:56 AM
Pedal Faster
Josh_Keady's Avatar
I think I'd pull that valve cover and crank it up. Squeaking is... not good.
Josh Keady
Josh_Keady is offline
post #3 of 4 (permalink) Old 01-29-2008, 12:14 PM
midnite93's Avatar
Squeaking usually means a lack of lubrication, there is a good chance the oil galleys are plugged.. Or the oil pump is weak and not supplying enough oil to reach the upper portion of the engine... OR, the bearing are worn so bad all the oil escapes before it reaches the top end...
I could go like this all day, without knowing more of the condition of the engine it is impossible to give you one correct answer..
1993 Thunderbird LX 3.8 AOD. My toy
1997 F-250 HD Extended cab, long bed, 5.8L, E4OD.
midnite93 is offline
post #4 of 4 (permalink) Old 01-29-2008, 10:39 PM Thread Starter
well my oil preassure guage Electronic suddenly drops for no reason and then comes back up like once a day but its been doing that for about a year and a half so i figured it was a guage problem
