Underdrive pully dyno sheets - TCCoA Forums
post #1 of 5 (permalink) Old 02-14-2008, 11:17 AM Thread Starter
anyone have dyno sheets showing gains from ud pullies alone? I read an article on some site tht i cant find saying that after running a car with no belt at all they only gained 3hp so im skepticle.
MikeRWK is offline
post #2 of 5 (permalink) Old 02-14-2008, 11:34 AM
mechman1984's Avatar
Underdrive pulleys do not free up much horsepower at all. Most companies say 10-12 but in reality it is generally about 3-7 or so. The link below was done on a 6.0L 2500 Series with ac. That claim is pretty accurate.
http://www.slponline.com/coming_soon_100230.asp
Will
08 Ford Ranger
95 Thunderbird V8-Sold!
mechman1984 is offline
post #3 of 5 (permalink) Old 02-15-2008, 06:21 PM
Here is a semi-relevant dyno sheet from my Splitport 94 LX. The difference between the two pulls was that on the blue one I had installed a 25% UD crank pulley, swapped from the stock 94 exhaust to a much better flowing setup (click here for info on that), and tuned for 93 octane as opposed to 87 octane.
Keep in mind, that was back in 2003. If I felt like messing with the tune, I'm sure I could get more power out of the car now.
-Rod
post #4 of 5 (permalink) Old 02-15-2008, 07:27 PM
cmill95's Avatar
exactly how much power do you think the exhaust attributed to that much of an increase?
cmill95 is offline
post #5 of 5 (permalink) Old 02-16-2008, 04:48 AM
I'm not going to speculate there. It is evident that the exhaust did help in the upper rpm's, but as to numbers, I don't have a definite answer.
-Rod
