Codes & Questions - TCCoA Forums
post #1 of 7 (permalink) Old 02-18-2008, 03:46 PM Thread Starter
Codes & Questions
My CEL light i on and going by receipts and things that came with the car its throwing these codes:
p0136
p0156
p0172
p0175
On the reapir report its marked that its caused by either and EGR malfunction or a vacuum leak, When the EGR malfunctions on these cars is it usually dead or just dirty?
MikeRWK is offline
post #2 of 7 (permalink) Old 02-18-2008, 04:56 PM
Neither. Usually it's a bad DPFE sensor.
post #3 of 7 (permalink) Old 02-18-2008, 04:57 PM Thread Starter
I probably should have mentioned im also getting a stumble/hesitation.
MikeRWK is offline
post #4 of 7 (permalink) Old 02-19-2008, 01:32 PM Thread Starter
Wouldnt it throw EGR codes if it were the DPFE or EGR?
MikeRWK is offline
post #5 of 7 (permalink) Old 02-19-2008, 11:30 PM
96PRLBRD's Avatar
Look up your codes here, should give you plenty to chew on:
http://www.obd-codes.com
96PRLBRD is offline
post #6 of 7 (permalink) Old 02-20-2008, 05:08 AM
Looks like you have bad O2 sensors.
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0172 System too Rich (Bank 1)
P0175 System too Rich (Bank 2)
You can check here also to see what the codes are.
A bad DPFE will throw an EGR code.
post #7 of 7 (permalink) Old 02-20-2008, 03:59 PM Thread Starter
Yeah i figured they were gone.
MikeRWK is offline
