new maf sensor, still getting cel - TCCoA Forums
post #1 of 4 (permalink) Old 02-20-2008, 08:39 AM Thread Starter
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
i pulled codes 157 and 158 a few months ago, found out the maf voltage is too high and low, replaced it with a new one, everything was fine and dandy, and now my cel has come on again, spitting out the same codes. i pulled the sensor, and the wires look clean. im lost as to why im getting the sames codes two months after replacing the maf. it did rain pretty good the night before it came on, but i dont recall driving through any puddles.
2014 GT
1990 300ZX TT
big mike is offline
post #2 of 4 (permalink) Old 02-20-2008, 09:15 AM
cmill95's Avatar
check the voltage on your TPS.
cmill95 is offline
post #3 of 4 (permalink) Old 02-20-2008, 03:47 PM Thread Starter
Motorboatin' SOB
big mike's Avatar
how do i do that? am i looking for 12v?
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 4 (permalink) Old 02-20-2008, 05:55 PM
cmill95's Avatar
no not 12 volts. check the lower 2 wires(there is three arranged vertically). also, you could just check the middle wire and ground the other end of your multimeter. setting you meter at 2V of course.
voltage should be 0.97 volts at idle.
i had a problem with Red that the voltage was 4.870 + or - at idle. way outta wack! had to replace that one.
cmill95 is offline
